Default stroke weight not "holding"
So I have this issue on both the Dimensioning tool and the label tool (text box with leader). I want the default stroke weight to be 0.5. So with either tool, I select the tool, and without doing anything else, I set the stroke weight to 0.5. Then I immediately use the tool. Great, as far as I know, that's how you set the default tool settings. If I come back and select the tool later, the stroke weight does show 0.5 when I go to use it. But after I finish dimensioning, let's say, the strokes looks a heavy...and yes, if I then select those dimensions, the stroke weight is 1.0 and I have to change them to 0.5. Has anybody else seen this, and am I doing something wrong?
What you describe is the right way to set the stroke weight and it should hold once you've set it. I've heard of other folks having issues with certain settings not being remembered. The problem in those cases was traced to incorrect installation of SketchUp/LayOut. Perhaps that's the problem this time. When you installed SketchUp, did you right click on the installer and choose Run as administrator? If not, the installation wasn't done correctly. Try doing that now. After clicking on Run as administrator a window should open with some different options. Choose Repair. It's important to note that being logged in as Administrator is not the same as Run as administrator.
OK, So I reran the sketchup pro installation by clicking Run as Administrator, and I chose Repair. Just tried dimensioning as described before, and it's still doing it (making the stroke weight 1.0 when 0.5 or even 0.6 is selected). Ugh.
Hmmm....
I just tested again and I can't duplicate that behavior. It holds the last line weight setting I made.
To make sure all the changes from Reinstalling take effect, try a cold reboot of your computer.
Cold reboot and the problem is still there. Bummer. Fortunately, I'm putting all my dimensions on their own layer, so it's easy enough to isolate that layer, select them all, and change them all at once. It would be better not to have to do that at all.
Yes. It would be better not to have to do that. You shouldn't need to.
What happens if you get the Dimension tool, hit S, and click on an existing correct dimension? Can you place additional dimensions with that line weight?? Does it stick after that?
Yes, that does work. The stroke weight of 0.5 (the one I sampled) sticks. I may just sample them before dimensioning, though I'm a big keyboard shortcut fan, so I use the D key a lot when I'm switching. (I've got D set for the dimensioning tool, don't remember if that is default or not)
D is the default for the Linear Dimension tool. If you needed to sample an existing dimension, you should be able to hit D and then S.
If you're going to use the same line weight for all of your dimensions, why not just make a template with those settings? Then you wouldn't have to change them. Adjust font, end styles, and extension lines, as well as styles for labels and other text, dimension units, default line style for the drawing tools, and add borders and title blocks as needed. Also add layers for the various entity types. My templates have multiple layers for model viewports and I have the lowest one of them set as the active layer so when I use Send to LayOut, the first viewport is on that layer and I don't have to change it. If your projects typically run multiple pages, make additional pages while you're at it.
So I had to go away, came back and rebooted. The stroke line weight is now "sticking" for the dimensioning tool. However, a new problem cropped up. In the attached snip, I grabbed the corners circled in red with the dimension tool, dragged the dimension straight down, and the legs turned out as shown. I've tried re-running the SU install (Run as Admin), and rebooted, and the same problem occurs.
I'm glad your dimensions are sticking now. Can you upload the LO file or send it to me in a PM?
It's 89 MB. I'm guessing it's over limit.
Found a solution: I sampled another dimension in a scrapbook I got from someone. That dimension worked as normal. So I stopped there, changed the default text, stroke, etc to what I use and the legs are acting normal again. Back to work...!
Good enough. I t would interesting to see how you went about making and placing that weird dimension, though.
Register LoginAdvertisement
