    Building Massing Blocks - Area Report
    4 Posts 1 Posters 7.3k Views 1 Watching
    • A
      ArtPen
      Hi guys,
      Just want to check with you a couple of things regarding dynamic components.
      I am trying to make a Building block which will report all the necessary information to SketchUp report.
      1. Why FACEAREA() returns area which is 2 times bigger then it supposes to be?
      2. I want a user to be able to select Building Use which will change a colour of the component. It seems straightforward, but how to report not a colour but actual usage?
      3. Also is there a way to have a component name above it? So it easy to see where components with wrong names?
      I have attached images so its easier to understand what I want to get.
      Thank you!
      Area is wrong
      Color has a value, but I want to report string - residential
      How automatically add labels
      BLOCK A.skp
      • A
        ArtPen
        Ok, I have resolved the problem with Areas.
        Do you have an idea about 2 and 3?
        Thank you
        • A
          ArtPen
          So FACEAREA() doesn't work after all. ))
          Does anyone knows how to get a correct area from the component using FACEARAE() function?
          Redraw command doesn't update the area after changing component size via "User Text Box"
          I switched off scale handles
          User can enter LenX and LenY in a text box
          After changing the values of LenX and LenY Area is wrong!
          Also any ideas regarding questions 2 and 3?
          • A
            ArtPen
            Had anyone the same problem? maybe it possible to write a custom script to measure the area and attach it to DC?
