    Getting group's dimensions
    7 Posts 3 Posters 1.4k Views 3 Watching
      Sweek
      Hello,
      I'm new here and I need help for my project. I try to get width, height and depth of my selected entities.
      For example, this is my project's hierarchy:
      http://sketchucation.com/forums/download/file.php?mode=view&id=147002&sid=1873d96db67d9c19c9fd179524a03797
      model = Sketchup.active_model
      selection = model.selection
      selection.each do |entity|
        UI.messagebox(entity.name)
        entity.entities.each do |sub_entity|
          UI.messagebox(sub_entity.name)
      With this code, if I select A, I get the group A, 1 and 2. Now I'd like to get each group's dimensions. I tried this:
        bb1 = Geom;;BoundingBox.new
        bb1.add(entity.bounds)
        UI.messagebox("Name; #{entity.name}\nWidth; #{bb1.width}\nHeight; #{bb1.height}\nDepth; #{bb1.depth}")
          bb2 = Geom;;BoundingBox.new
          bb2.add(sub_entity.bounds)
          UI.messagebox("Name; #{sub_entity.name}\nWidth; #{bb2.width}\nHeight; #{bb2.height}\nDepth; #{bb2.depth}")
          bb2.clear
        bb1.clear
      If I select the A group I get the right values for A but not for its subgroups 1 and 2.
      If I select the subgroup 1, I get the right values for the subgroup 1.
      If you can explain me why I get this, or tell me how to get what i want. I would appreciate.
        Your code looks workmanlike.
        When I create a set of nested groups as you propose I get the results I'd expect ??
        What is 'wrong' with your results ?
          Sweek
          Thanks for your answer. I will try to explain.
          I made this:
          -group B size is 15126,
          -group 3 size is 15123,
          -group 4 size is 15123
          http://sketchucation.com/forums/download/file.php?mode=view&id=147016&sid=0a3ceca0aaca666d6788aa408da8a10b
          If my selection is B like this:
          http://sketchucation.com/forums/download/file.php?mode=view&id=147017&sid=0a3ceca0aaca666d6788aa408da8a10b
          I get this results (which are right only for group B):
          http://sketchucation.com/forums/download/file.php?mode=view&id=147018&sid=0a3ceca0aaca666d6788aa408da8a10b
          http://sketchucation.com/forums/download/file.php?mode=view&id=147019&sid=0a3ceca0aaca666d6788aa408da8a10b
          http://sketchucation.com/forums/download/file.php?mode=view&id=147020&sid=0a3ceca0aaca666d6788aa408da8a10b
          As you can see, for group 3 and 4 the width is not correct.
          But if my selection is 4 for example:
          http://sketchucation.com/forums/download/file.php?mode=view&id=147021&sid=0a3ceca0aaca666d6788aa408da8a10b
          I get right results for group 4:
          http://sketchucation.com/forums/download/file.php?mode=view&id=147022&sid=0a3ceca0aaca666d6788aa408da8a10b
          Usually, how do you get the size of all groups in a model ?
          • sdmitchS Offline
            sdmitch
            Just how did you create 3 and 4 inside of B?
            If I create 3 and 4, stack them, then group them to create B, your code works as expected.
            http://sdmitch.blogspot.com/
              Sweek
              Effectively, I tried as you said and it works.
              I will ask my internship supervisor how he created his groups.
              Do you know if people get group's dimension like I did or if they use another way ?
              • sdmitchS Offline
                sdmitch
                Be aware that bounds dimensions of the container 'B' can and do change when rotated. The sub_groups, 3 and 4, are unaffected. Creating a new bounding box isn't necessary. It will be the same as the entities bounds. Use .local_bounds for the container, which gives you the initial dimensions, then use the x,y and z scales from the transformation to give you the current size.
                  bb1=entity.local_bounds; tr1=entity.transformation
                  UI.messagebox("Name; #{entity.name}\nWidth; #{bb1.width*tr1.xscale}\nHeight; #{bb1.height*tr1.yscale}\nDepth; #{bb1.depth*tr1.zscale}")
                    bb2=sub_entity.bounds
                  Sweek
                  Thank you, I will work on this.
