    Installing sketchup and net framework
    6 Posts 6 Posters 2.1k Views 6 Watching
      Jvenning
      I have two queries:
      First is I can't install sketchup on my laptop with windows 7 os. The Net framework 4 starts installing but the progress bar reaches the end and goes back to beginning and never finishes. I've tried skp 2015, 16 and 17 and have tried deleting net framework from my computer and clean reinstalling and tried the standalone installer online but that one does nothing at all(progress bar doesn't move at all when left on all day).
      Secondly, anyone know of a plugin to export 2d cad lines from the section tool, it would save me making a rectangle, intersecting face with model etc everytime I want to export.
      • mitcorbM Offline
        mitcorb
        Hi.
        The issue in your first paragraph is not within my skillset.
        The issue in your second paragraph suggested TIG's Section Cut Face. That plugin has been around a few years. It basically builds a plane on the Sketchup section plane you designate.
        I think that's right. Or, I have found another item not in my skillset. 💚
          Charlie__V
          Have you tried manually installing 4.5.2 .net framework?
          Edit: I read your post too quickly...looks like you have tried the "standalone" installer....sorry I have no other solution
          See SU help center:
          https://help.sketchup.com/en/article/57603
          C
          Edit:#2
          I had this same problem and I cannot recall the order of install but I believe you have to do the C++ runtime install as well (maybe before .net install?)
          see paragraph #5 of this link
          • Louis GordonL Offline
            Louis Gordon
            You need install net framework 4.0 or 4+
              dtrarch
              Jvenning
              I had the same issue.
              For me it was Firefox and it's new security. 👿 👿 👿
              I went to MS Explore and Bingo.
              Hope this helps.
              Cheers
              dtr
              • sketch3d.deS Offline
                sketch3d.de
                try if installing the Windows runtime libraries required by SU v2016/2017 again helps:
                • Microsoft .NET Framework v4.5.2+
                • Microsoft Visual C++ Redist. 2015
                • Microsoft Universal C Runtime Update f. Win 7/8.x
                always run these installers (as well as the SU setup) by "r-click > Run as Admin".
