    Double-Cut - Cut through double-sided walls
    extensions
    44 Posts 19 Posters 21.8k Views 19 Watching
      jasondag
      thx for responding.
      Yes, licence installed, rebooted..etc. The drop down menu seems to work but the options are all greyed out. I'm admittedly very new to this, but despite all the component tutorial videos I've seen (creating the object within a wall, creating component, etc...), I cant figure out what I'm missing for the ext to work.
      • W Offline
        Whaat
        @raggith said:
        Just downloaded and tried Double Cut. 2 Big problems though;
        1. It works great until you group the wall, then it reverts to single cut native mode.
        2. Section fill (both Skalp and Native SI) does not work with Double Cut. i assume this is because the internal cut faces of the opening are grouped with the window (cutting object) not the wall (the object being cut.
          It would be a great pluggin that I'd definitely buy if they fixed these issues.
        Hi Raggith, thanks for your interest in Double-Cut.
        1. Best to group the wall first, then double-click it and bring in the cutting component. If this isn't your preferred way to work, that's fine. After grouping the wall and cutting component, you just need to use the Double-Cut refresh feature to redo the cuts. It's another step, but it's really quick.
        2. You need to use the explode feature in Double-Cut if you want to work with filled section cuts. This is a limitation of SketchUp cutting components. But if you use the explode feature, the sections cuts will work as expected.
        Please check out our new tutorials which go into detail for how to use the various tools.
        https://mindsightstudios.com/double-cut/
        • W Offline
          Whaat
          @jasondag said:
          thx for responding.
          Hi Jason,
          I assume you are the same Jason that sent us a support request. It seems that you were using the old Double-Cut version that included the right-click context menu. If you update to the new version 1.1.0, you will find it much easier to use. We made a lot of nice improvements so it should be more intuitive.
          Plus we added some new high-quality tutorials!
          Thanks for your interest in Double-Cut
          • W Offline
            Whaat
            @halroach said:
            I think I found a bug which causes Sketchup to crash. I seem to have narrowed it down to double-cut, and specific dynamic components. It happened to me on 3 different PCs with windows 10 and Sketchup 2017.
            Hi Halroach. We looked into this bug report but we could not reproduce it using version 1.1.0.
            Have you tried the new version? Maybe the crash has been resolved.
            Thanks!
            • 3 / 3
