    Protractor is becomes super small when texturing
    3 Posts 3 Posters 663 Views 3 Watching
      robindmt
      Hello all!
      So when i texture the furniture i work on, sometimes the protractor that appears when you change the position of a texture becomes super small compared to my texture which makes it complicated to see what i'm doing and to be precise as well.
      I've had this issue multiple times, it's not the end of the world but i would like to understand why it happens. Sometimes, i just go get the texture again and it appears at the normal size.
      Not sure if i'm being clear, let me know if you have any questions!
      Thanks a lot,
      Robin
        Make some images with pressing the Key "Print Screen"! πŸ˜‰
          Very likely it has to with the material size relative to the size of the object you are texturing. Could you upload an example SKP file that shows this so we can take a look and give you some help?
