Noob help with Sketch
Noob here (sorry!).
I'm getting to grips with Sketchup and have started to build projects but have hit an issue with the latest one. I've been designing a tiered cake stand (exciting I know!) that I'll be intending to make out of 1/4" ply. The round tiers are in, as are the stands that slot in the middle to form the cake stand. The problem I am having is to remove the sections where the stand uprights pass through the centre of the tiers. I can subtract two of the uprights from one of the tiers but it leaves me with a tier that is no longer a solid. Solid Inspector is flagging problems that need to be corrected manually and that's where I get into a deeper muddle!
If anyone is able to give me any advice or solutions that would help solve this I'd be very grateful.
Cheers
Ben -
Are you all set now?
Register LoginAdvertisement
