    Draw vs. Import Component
    3 Posts 2 Posters 1.0k Views 2 Watching
    • medeekM Offline
      medeek
      I'm trying to determine if its easier to write a module that draws an anchor bolt (L-bolt with square washer and nut) or just bring in the component (pre-drawn). I've never brought in a component before so something I need to explore further. The other thing I feel is key is to make sure any of these minor components are modeled in such as way as to remain fairly lightweight within the model.
      Are there any caveats with bringing in components via the API that I should be aware of?
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        So I've loaded three components (sketchup files) from my components folder, a bolt, washer and nut and now I want to combine them all into one component, any hints?
        design.medeek.com
          You could have the three parts assembled into another SKP in your folder and then load that - bringing in the assembly and the three parts.
          However, if you want to add a new component into the model then use something like:
          model = Sketchup.active_model
          ### set up names of parts
          bolt = "MyBolt"
          washer = "MyWasher"
          nut = "MyNut"
          ### here I'm assuming they are already loaded [OR add then now]...
          ### get a reference to each from the name...
          defn_bolt = model.definitions[bolt]
          defn_washer = model.definitions[washer]
          defn_nut = model.definitions[nut]
          ### now combine them - add new empty definition
          name = "MyAssembly"
          path = Filejoin(path_to_folder, name+".skp")
          defn = model.definitions.add(path)
          name = defn.name ### in case name is preexisting, and it's now "MyAssembly#1"
          ### establish a suitable transformation of each component part - here I'll just call it 'tr_bolt' etc
          ### because the tr is within the definition's entities, center parts on the ORIGIN
          ### and move the nut/washer along the Z as needed
          ### a good idea would be to have the component parts with their insertion points
          ### at their ORIGINS and the bolt shaft facing down in the Z etc ?
          defn.entities.add_instance(defn_bolt, tr_bolt)
          defn.entities.add_instance(defn_washer, tr_washer)
          defn.entities.add_instance(defn_nut, tr_nut)
          ### you place the assembly 'defn' the same way, with another suitable transformation...
          some_entitites_collection.add_instance(defn, tr_defn)
