    Modern lake house
    45 Posts 7 Posters 11.2k Views 7 Watching
    • Bryan KB Offline
      This one is going to take a while.
      First I selected the terrain.
      In SketchUp: File>Geo Location>Add Location. Select location in the mini Google Earth Map. It will then automatically place the location as a flat image in your workspace.
      Then select File>Geo Location>Show Terrain. It will then automatically contour the terrain.
      Build the model as a separate file and then import into first terrain model.
      As changes are made to the house model, you simply reload the model in the terrain model to update changes.
      Once the model is completed, I will then refine the terrain and add water and vegetation.
      • ntxdaveN Offline
        ntxdave
        Nice little tutorial. I will have to give it a try.........
        Press F1...thank me later
        • Bryan KB Offline
          Scale reference. You can barely see "whats-his-name" inside.
          • Bryan KB Offline
            Interior floors finished and solar panels and wind turbines added.
            Interior walls, windows, furniture and fixtures next.
            • Bryan KB Offline
              Turned off textures and only using shaded.
              • Bryan KB Offline
                Coming along nicely.
                • Bryan KB Offline
                  Updates.
                  • Bryan KB Offline
                    Testing furniture and room spaces.
                    • Bryan KB Offline
                      Early render tests. A lot will change before it's finished. Just playing around right now.
                        Interesting build, intriguing concept, I like that last view. Very modern feel.
                        • Bryan KB Offline
                          Thanks Mike!
                          Here are some minor updates. Just fooling around with decor. I did change the stairwells to glass instead of the vertical bars.
                            mwm5053
                            I like it Bryan, nice concept, model, very interesting.
                            2011 iMac
                            SU 2015 Pro, 2017 Make
                            V2 Twilight
                            macOS Sierra 10.12.5
                            • Bryan KB Offline
                              Thanks Walt.
                              • Bryan KB Offline
                                Still just testing and rearranging things.
                                  It may be me but I like the definition given by the bars.
                                  • pbacotP Offline
                                    I like the glass better. It's in keeping with the exterior glass and the bars seem heavy. Maybe provide definition some other way. I don't know that the glass would be so thick but it could have reinforcing (glass) fins to add detail. It gives more the appearance of passing vertically through the floors like a single, continuous vertical element,which I like.
                                    • Bryan KB Offline
                                      I liked the bars as well but it did block the view and light. I also realized is was a 1950s-60s decor style and while I love mid-century design, it was not right for this house.
                                      The glass is actually acrylic which is lighter, safer and more durable than glass.
                                      • tuna1957T Offline
                                        tuna1957
                                        definitely different 👍 . can't image what the "window" would cost ... and look out for the kid with a "BB" gun..
                                        • Bryan KB Offline
                                          Thanks Charles.
                                          It's all acrylic. The real problem would be cleaning it!
                                          • DanielD Offline
                                            Daniel
                                            It's interesting. Very futuristic looking. However, to be in such a beautiful setting and yet be detached from it (your literally in a bubble) seems contrary to the point of even being there. You can't even step outside on a balcony to enjoy the air.
                                            My avatar is an anachronism.
                                            • 1 / 3
