How to align plane with view port?
As opposed to aligning view port with plane. Is this possible?
If you use the axis tool and right-click, I think you can align axis with view. Then you can draw your plane there.
I might be wrong and I can't test it right now.
Copy and paste this code into the Ruby Console. It will draw a Construction line along the view direction of the camera. Then you can place the Axis along the cline and construct geometry which is aligned to the Axes.
Sketchup.active_model.entities.add_cline(Sketchup.active_model.active_view.camera.eye,Sketchup.active_model.active_view.camera.direction) -
Helpful. Thanks Jim
Register LoginAdvertisement
