    Medeek Wall Plugin
    1.5k Posts 27 Posters 994.0k Views 26 Watching
    • gullfoG Offline
      gullfo
      could you also do a 10 year? i'm pretty sure i'll be gone in 8... πŸ˜›
      Glenn
      http://www.runnel.com
      • medeekM Offline
        medeek
        Version 3.2.9 - 09.14.2023
        • Fixed a critical bug with loading wall presets in the wall edit menu (metric and imperial).
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM Offline
          medeek
          What should I charge if I did a 10 year?
          $280.00 X 2 = $560.00
          I would probably be more inclined to charge this for a 5 year license.
          design.medeek.com
          • medeekM Offline
            medeek
            I realize that for many of my older customers (myself included) a 30 year license really has no practical meaning and having to invest almost a thousand dollars is a lot for anyone.
            For those that do not want to outlay as much money but still would like to get a multi-year discount I am also offering a 5 year license for $560.00, so basically you are getting five years for the price of two, which is still a fairly substantial discount, but not as deep as the 30 year discount rate. Basically it would be equivalent to paying $112.00 per year for the mdkBIM bundle for a total of five years.
            design.medeek.com
            • medeekM Offline
              medeek
              To better fill the gaps in the mdkBIM Multi-year licensing I've decided to offer one additional licensing price point. The three permanent licensing options (multi-year) are:
              5 Year - $560.00 (Discount Code: MDK5YEAR)
              10 Year - $770.00 (Discount Code: MDK10YEAR)
              30 Year - $980.00 (Discount Code: MDKLIFE)
              Each price point offers a progressively steeper discount as the number of years of licensing increases.
              To purchase a lifetime license, login to the Account Manager and then click on the mdkBIM icon. Click on purchase mdkBIM Suite, then enter in one of the discount codes above. You will notice that the price will adjusted accordingly and the expiration update date will also reflect the multi-year license.
              As mentioned previously if a multi-year license is purchased I am also willing to thrown in the Electrical plugin license at no additional cost and its license will also reflect the same number of years as whatever multi-year option was chosen.
              design.medeek.com
              • medeekM Offline
                medeek
                Version 3.3.0 - 09.21.2023
                • Moved the Geometry Markers section from the General tab to the Walls tab in the Global Settings.
                • Added a geometry marker size parameter to the Walls tab of the Global Settings.
                The General tab of the Global Settings has become too large (or cluttered) and it made sense to move the geometry markers to the Walls tab. I also received a number of requests about making the geometry markers larger. So I figured, why not let the user customize them to the size they would like.
                http://design.medeek.com/resources/wallplugin/images5/wall_su713_800.jpg
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 3.3.1 - 09.27.2023
                  • Fixed a bug with the labeling algorithm for the molding module.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 3.3.2 - 10.10.2023
                      • Added the Draw Wall Perimeter tool to the Medeek Wall Tools II toolbar.
                      (The tool icon was added July 25th, but now it actually works)
                      Tutorial 42 - Wall Perimeter Tool (5:28 min.)
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        mdkBIM Tutorial 3 - Modeling a House Envelope from a Face (10:04 min.)
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 3.3.3 - 10.18.2023
                          • Fixed a minor bug with the post module.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 3.3.6 - 10.20.2023
                            • Sheathing Vertical Offset parameters added for attic trusses.
                            • Cladding Vertical Offset parameters added attic trusses.
                            • Wall Cladding Gap parameter added for common, monopitch and attic trusses.
                            http://design.medeek.com/resources/trussplugin/images4/truss_su818_800.jpg
                            The wall cladding gap parameter was added to bring the Truss plugin inline more with the Wall plugin.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 3.3.4 - 10.23.2023
                              • Added a "Assign to 2D Layer" parameter for 2D Outlines within the General tab of the Global Settings.
                              • Added the Opening tool to the Medeek Wall Tools II toolbar.
                              http://design.medeek.com/resources/wallplugin/images5/wall_su715_800.jpg
                              http://design.medeek.com/resources/images/wall_tools2_su_menu_active.jpg
                              The Opening Tool in its current state can be used only to toggle door swings. I will probably be adding additional functionality to this tool for windows and garage doors as well as regular man doors. This new tool is in response to feedback provided by Matt Donley of MasterSketchUp.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 3.3.4 - 10.25.2023
                                • Updated the Opening Tool to include Windows and Garage Doors.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Tutorial 43 - Opening Tool (6:01 min.)
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 3.3.5 - 11.09.2023
                                    • Added the Copy Opening Tool to the Medeek Wall Tools II toolbar.
                                    • Enabled the Copy Opening Tool for Windows, Man Doors and Garage Doors.
                                    • Enabled subtractive geometry for Beam Assemblies.
                                    • Added additional W-Flange steel beam sizes.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Tutorial 44 - Opening Copy Tool (4:45 min.)
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        I will be running a Thanksgiving promotion beginning Nov. 12th until Dec. 1st. with 40% off of the regular mdkBIM bundle price (permanent license) using the coupon code GIVETHANKS23.
                                        This will reduce the bundle price from $280.00 USD to $168.00 USD. This promo code does not apply to any of the extensions purchased separately or for the electrical plugin. The offer ends on Dec. 1 and no rain checks will issued thereafter.
                                        Medeek Design Inc. - Garage, Shop, Shed and Barn Plans
                                        (design.medeek.com)
                                        https://global.discourse-cdn.com/sketchup/original/3X/7/e/7e084d84a01860096ecb19d2a23a6ef8937179c3.jpeg
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          First look at my attempts to simplify the look and feel of the Draw and Edit menus for walls:
                                          https://global.discourse-cdn.com/sketchup/optimized/3X/3/f/3fcfa13f26c1462c19ba81a6303a8e5d7170b1e8_2_633x500.jpeg
                                          https://global.discourse-cdn.com/sketchup/original/3X/c/e/cec8d04e4467e2c59ac4892a7df20b91ae8ace49.jpeg
                                          I'm no UI expert but my idea is to create collapsible menus for certain sections that are not modified as commonly during regular use. The "wall start" and "wall end" sections are a good examples of such sections. Typically the parameters within these two sections are only modified in certain specific situations or when customization is required.
                                          Thoughts?
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            After shuffling things around a bit:
                                            https://global.discourse-cdn.com/sketchup/original/3X/9/f/9fad44c6635b574b22ddd03fedfce1e6376324bb.jpeg
                                            https://global.discourse-cdn.com/sketchup/original/3X/7/2/72e7043b13ebaefed5d51934f0261e3aafbc5831.jpeg
                                            I've created a new section for framing options/details. Notice that in this section I've also moved the stud removal parameter, which was formerly in the advanced options (I think it makes more sense to place it in this section).
                                            The advanced options section is unchanged and still very busy with a ton of parameters but I really don't know what to do about it since all of those advanced options are necessary and need to be placed somewhere. (If you disable the Advanced Wall Options then that whole section is not shown.)
                                            So currently, with the new UI update so far, there are three sections that can be toggled by the user manually. I should probably also add into the global settings some parameters which will control the default visibility for these sections.
                                            design.medeek.com
                                            • 64
                                            • 65
                                            • 66
                                            • 67
                                            • 68
                                            • 73
                                            • 74
                                            • 66 / 74
