    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • medeekM
      medeek
      Version 3.3.2 - 10.10.2023
      • Added the Draw Wall Perimeter tool to the Medeek Wall Tools II toolbar.
      (The tool icon was added July 25th, but now it actually works)
      Tutorial 42 - Wall Perimeter Tool (5:28 min.)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        mdkBIM Tutorial 3 - Modeling a House Envelope from a Face (10:04 min.)
        design.medeek.com
        • medeekM
          medeek
          Version 3.3.3 - 10.18.2023
          • Fixed a minor bug with the post module.
          design.medeek.com
          • medeekM
            medeek
            Version 3.3.6 - 10.20.2023
            • Sheathing Vertical Offset parameters added for attic trusses.
            • Cladding Vertical Offset parameters added attic trusses.
            • Wall Cladding Gap parameter added for common, monopitch and attic trusses.
            http://design.medeek.com/resources/trussplugin/images4/truss_su818_800.jpg
            The wall cladding gap parameter was added to bring the Truss plugin inline more with the Wall plugin.
            design.medeek.com
            • medeekM
              medeek
              Version 3.3.4 - 10.23.2023
              • Added a "Assign to 2D Layer" parameter for 2D Outlines within the General tab of the Global Settings.
              • Added the Opening tool to the Medeek Wall Tools II toolbar.
              http://design.medeek.com/resources/wallplugin/images5/wall_su715_800.jpg
              http://design.medeek.com/resources/images/wall_tools2_su_menu_active.jpg
              The Opening Tool in its current state can be used only to toggle door swings. I will probably be adding additional functionality to this tool for windows and garage doors as well as regular man doors. This new tool is in response to feedback provided by Matt Donley of MasterSketchUp.
              design.medeek.com
              • medeekM
                medeek
                Version 3.3.4 - 10.25.2023
                • Updated the Opening Tool to include Windows and Garage Doors.
                design.medeek.com
                • medeekM
                  medeek
                  Tutorial 43 - Opening Tool (6:01 min.)
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 3.3.5 - 11.09.2023
                    • Added the Copy Opening Tool to the Medeek Wall Tools II toolbar.
                    • Enabled the Copy Opening Tool for Windows, Man Doors and Garage Doors.
                    • Enabled subtractive geometry for Beam Assemblies.
                    • Added additional W-Flange steel beam sizes.
                    design.medeek.com
                    • medeekM
                      medeek
                      Tutorial 44 - Opening Copy Tool (4:45 min.)
                      design.medeek.com
                      • medeekM
                        medeek
                        I will be running a Thanksgiving promotion beginning Nov. 12th until Dec. 1st. with 40% off of the regular mdkBIM bundle price (permanent license) using the coupon code GIVETHANKS23.
                        This will reduce the bundle price from $280.00 USD to $168.00 USD. This promo code does not apply to any of the extensions purchased separately or for the electrical plugin. The offer ends on Dec. 1 and no rain checks will issued thereafter.
                        Medeek Design Inc. - Garage, Shop, Shed and Barn Plans
                        (design.medeek.com)
                        https://global.discourse-cdn.com/sketchup/original/3X/7/e/7e084d84a01860096ecb19d2a23a6ef8937179c3.jpeg
                        design.medeek.com
                        • medeekM
                          medeek
                          First look at my attempts to simplify the look and feel of the Draw and Edit menus for walls:
                          https://global.discourse-cdn.com/sketchup/optimized/3X/3/f/3fcfa13f26c1462c19ba81a6303a8e5d7170b1e8_2_633x500.jpeg
                          https://global.discourse-cdn.com/sketchup/original/3X/c/e/cec8d04e4467e2c59ac4892a7df20b91ae8ace49.jpeg
                          I'm no UI expert but my idea is to create collapsible menus for certain sections that are not modified as commonly during regular use. The "wall start" and "wall end" sections are a good examples of such sections. Typically the parameters within these two sections are only modified in certain specific situations or when customization is required.
                          Thoughts?
                          design.medeek.com
                          • medeekM
                            medeek
                            After shuffling things around a bit:
                            https://global.discourse-cdn.com/sketchup/original/3X/9/f/9fad44c6635b574b22ddd03fedfce1e6376324bb.jpeg
                            https://global.discourse-cdn.com/sketchup/original/3X/7/2/72e7043b13ebaefed5d51934f0261e3aafbc5831.jpeg
                            I've created a new section for framing options/details. Notice that in this section I've also moved the stud removal parameter, which was formerly in the advanced options (I think it makes more sense to place it in this section).
                            The advanced options section is unchanged and still very busy with a ton of parameters but I really don't know what to do about it since all of those advanced options are necessary and need to be placed somewhere. (If you disable the Advanced Wall Options then that whole section is not shown.)
                            So currently, with the new UI update so far, there are three sections that can be toggled by the user manually. I should probably also add into the global settings some parameters which will control the default visibility for these sections.
                            design.medeek.com
                            • gullfoG
                              gullfo
                              maybe collapse the wall sheathing section as well so it's only opened if you need to edit it.
                              Glenn
                              http://www.runnel.com
                              • medeekM
                                medeek
                                Version 3.3.6 - 11.18.2023
                                • Added a "Menu UI" parameter in the General tab of the Global Settings with the following options: Legacy, Collapsed, Expanded.
                                • Updated the Wall Draw and Edit menus with the new Menu UI options.
                                • Fixed a bug with the tee intersection algorithm for rectangular "stacked" walls.
                                The additional menu options are in response to feedback from multiple users requesting a less busy and simpler menu system. By default the legacy menu system is selected in the global settings however one can quickly change to one of more advanced "collapsible" systems. This is my first real crack at this so further refinement may be necessary depending on the feedback I receive.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Tutorial 45 - Menu UI Options (8:08 min.)
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 3.3.7 - 11.20.2023
                                    • Fixed a bug with the hotkey (Up key) for wall panelization in the Draw Wall Perimeter tool.
                                    • Fixed a bug with the Draw Wall Perimeter tool for metric units.
                                    !!!! Critical Bug Fix !!!!
                                    This is a critical bug fix for users of metric units. I highly recommend upgrading to this latest version for all users.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 1.3.8 - 11.22.2023
                                      • Added two additional parameters for annotation formatting.
                                      • Added the "Regen Electrical" function to the primary toolbar, enabled regeneration for all electrical fixtures.
                                      • Moved the "Draw Safety Device" tool to the secondary toolbar.
                                      http://design.medeek.com/resources/electricalplugin/images2/elec_su237_800.jpg
                                      http://design.medeek.com/resources/images/electrical_su_menu_active.jpg
                                      http://design.medeek.com/resources/images/electrical_ii_su_menu_active.jpg
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 3.3.7b - 11.27.203
                                        • Fixed a critical bug introduced with Version 3.3.6.
                                        !!!! CRITICAL BUG FIX !!!!
                                        This is a critical bug fix for all users, please download the latest version of the plugin (3.3.7b).
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 3.3.8 - 12.02.2023
                                          • Updated the face selection algorithm of the draw wall perimeter tool.
                                          This addresses the issue of selecting faces that are embedded or nested within groups. You can now select faces that are in the root of the model or nested within other groups.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 3.3.9 - 12.18.2023
                                            • Added a "Cedar Siding" built-in material (horizontal) into the material library.
                                            http://design.medeek.com/resources/wallplugin/images6/wall_su723_800.jpg
                                            This material is a horizontal version of the previously added vertial version. This update per customer request.
                                            design.medeek.com
                                            • 64
                                            • 65
                                            • 66
                                            • 67
                                            • 68
                                            • 80
                                            • 81
                                            • 66 / 81
