    Trim multiple solids with one solid
    5 Posts 4 Posters 1.1k Views 4 Watching
    • K
      koliboti
      Hi, I have 248 Solid Groups which need to trim with 1 Big (green) Solid Group. It's possible to do with 1-2 clicks instead of 150 mouse clicks?
      • pbacotP
        sometimes you can take multiple objects which would be solids and group them together. They cannot be individually grouped. Then if the group shows solid you can trim in one shot. It can't work if the geometry of the parts inside is touching. Hope that is clear. Hard to describe. Test by drawing a set of clean cubes which are not touching and group. Trim with a solid group. So it may work if your 348 groups are not touching one another. You'd have to explode them all and group as one. I say it MAY work, because I don't know if this function has a limit in with such large group.
          Seems Bool tools 2 is for you ! πŸ˜„
          • gillesG
            gilles
            Fredo6 Visuhole:
            http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=59165#p538311
            Click to play the gif.
            • K
              koliboti
              Thank you guys very much! πŸ˜„
