    How to leave a watermark in an object or wall
    7 Posts 5 Posters 1.5k Views 5 Watching
    • G
      goto23
      Good day,
      I have a job in college and need to put a "watermark" on a wall or object, to signal that that object/wall was already modified. Anyone know any Ruby API the code that do this?
      I managed to leave this mark on the floor, but I would like to put on the wall and/or object
      Thank You
      • cottyC
        cotty
        I don't think you will get more answers if you start a new topic here and ignore slbaumgartners answer there:
        https://forums.sketchup.com/t/how-to-leave-a-mark-dwater-in-an-object-or-wall/39248
        my SketchUp gallery
          If i weel understand maybe Super Drape by Tig is made for that! πŸ˜„
          But you must before rotate wall to the horizontal! πŸ˜„
          • sfto1S
            sfto1
            slbaumgartners answer was/is very interesting. Is there a way to erase all instances of the component from the model, after the "watermarks" are no longer required with a single or few commands?
            • pbacotP
              All the water marks can be on a layer that you turn on or off. You could even date the layers for progress watermarks. (ok...who could be bothered?)
              The use of components seems a good choice since you are not altering the model geometry in any way. Easy to tag objects in one click.
              • G
                goto23
                Thanks for responding. I was trying to put into practice and better understand what he said.
                I tried to first use this code:
                model = Sketchup.active_model
                path = "Plugins"
                image_file = Sketchup.find_support_file("c.jpg", path)
                image = model.active_entities.add_image(image_file, ORIGIN, 30)
                And then the Face.get_glued_instances
                but the two code only the image on the floor and I can't take to the walls.
                • sfto1S
                  sfto1
                  I woke up with that thought. Thanks for confirming!
