    Issues moving objects
    5 Posts 2 Posters 630 Views 2 Watching
      bobrsta
      I'm hoping the forum can shed some light on an issue I'm having with the move tool:
      I'm well versed in using the Move tool, but it behaves very erratically. Typically, I'll grab an object by a relevant corner, initiate a move and lock direction using either one of the arrow keys or the shift key. But, as often as not, the object I'm trying to move jumps in the opposite direction of the one I'm attempting to move it! Orbiting to a different angle helps - sometimes. This seems to be something that gets progressively worse as I build my model; in a new model the Move tool seems to behave much more as expected. My current model has a little shy of 900,000 edges, 81,000 faces, almost 1000 component instances and a few more than 2000 groups in a 40 meg file. I don't know if that's pushing boundaries in Sketchup model size or what.
      Any ideas on how to get the tool to work more as expected?
      Thanks!
      Bob
        mwm5053
        Here's one I'm working on and am having the same problem. So what I have resorted to is finding a flat plane somewhere close to set the move point ( may not be on the component at all) to get it close and proceed from there. Sometimes it may take several moves with the inference lock direction always.
        2011 iMac
        SU 2015 Pro, 2017 Make
        V2 Twilight
        macOS Sierra 10.12.5
          mwm5053
          You might try this plugin from the Plugins store JF Moveit.
          2011 iMac
          V2 Twilight
            bobrsta
            yes, trial and error. seems to be a bug of some sort and it'd be nice to see Trimble fix that.
              bobrsta
              I will, thanks!
