    Polygon Tool
    8 Posts 3 Posters 1.7k Views 3 Watching
    • medeekM Offline
      medeek
      When it comes to creating "tools" within SketchUp I am severely handicapped. I kind of understand what is going on but it is more of black box to me than anything. With the code below I am trying to have the user input in a polygon that will be the perimeter of the slab foundation. I've got it mostly working but cannot figure out how to make it snap to the x and y axis or start and end points of lines. My code thus far is below:
      # Foundation POSITIONING LOGIC (Polygon)
      module FoundationPositionToolPolygon
      # --------  FOUNDATION POSITIONING TOOL  ------------------------------------------------
      # Positions the foundation assembly. This tool allows the user
      # to place the foundation assembly using the mouse to select a polygon
      class PositionToolPolygon
      	# Show the Ruby Console at startup so we can
      	# see any programming errors we may make.
      	# SKETCHUP_CONSOLE.show
      	#  these are the states that a tool can be in
      	STATE_EDIT = 0 if not defined? STATE_EDIT
      	STATE_PICK = 1 if not defined? STATE_PICK
      	STATE_PICK_2 = 2 if not defined? STATE_PICK_2
      	STATE_PICK_3 = 3 if not defined? STATE_PICK_3
      	STATE_PICK_FINAL = 4 if not defined? STATE_PICK_FINAL
      	STATE_MOVING = 6 if not defined? STATE_MOVING
      	STATE_SELECT = 7 if not defined? STATE_SELECT
      def initialize()
          	@tool_name = "FOUNDATION LOCATOR"
      	@type = "foundation"
      	@pointcount = 0
      def reset
          	@pts = []
          	@state = STATE_PICK
      	@pointcount = 0
          	# This sets the label for the VCB
          	Sketchup;;set_status_text "MEDEEK FOUNDATION", SB_VCB_LABEL
          	Sketchup;;set_status_text "[#{@tool_name}] Click first corner of Polygon"
      	@status_text = "[#{@tool_name}] Click first corner of Polygon"
          	@drawn = false
      def activate
          	@ip1 = Sketchup;;InputPoint.new
          	@ip = Sketchup;;InputPoint.new
          	self.reset
      def deactivate(view)
          view.invalidate if @drawn
          @ip1 = nil
      def onMouseMove(flags, x, y, view)
      	self.set_current_point(x, y, view)
      	Sketchup;;set_status_text @status_text,SB_PROMPT
      def onLButtonDown(flags, x, y, view)
          	self.update_state
      def set_current_point(x, y, view)
          if (!@ip.pick(view, x, y, @ip1))
              return false
          need_draw = true
          # Set the tooltip that will be displayed
          view.tooltip = @ip.tooltip
          # Compute points
          case @state
          when STATE_PICK
              @pts[0] = @ip.position
             	# need_draw = @ip.display? || @drawn
          when STATE_PICK_2
              @pts[1] = @ip.position
          when STATE_PICK_3
      	@pts[2] = @ip.position
          when STATE_PICK_FINAL
      	@pts[@pointcount] = @ip.position
          view.invalidate if need_draw
      def update_state
          case @state
          when STATE_PICK
              @ip1.copy! @ip
      	@pointcount = @pointcount + 1
              Sketchup;;set_status_text "[#{@tool_name}] Click second corner of Polygon"
              @state = STATE_PICK_2
      	puts "#{@state} #{@pointcount}"
      	@status_text = "[#{@tool_name}] Click second corner of Polygon"
          when STATE_PICK_2
              @ip1.clear
      	Sketchup;;set_status_text "[#{@tool_name}] Click third corner of Polygon"
              @state = STATE_PICK_3
      	@status_text = "[#{@tool_name}] Click third corner of Polygon"
          when STATE_PICK_3
              @ip1.clear
      	Sketchup;;set_status_text "[#{@tool_name}] Click fourth corner of Polygon"
              @state = STATE_PICK_FINAL
      	@status_text = "[#{@tool_name}] Click fourth corner of Polygon"
      	@ip1.clear
      	ptcurrent = @ip.position
      	@distorigin = @pts[0].distance ptcurrent
      	if (@distorigin > 0.0001)
      		@nextpointcount = @pointcount + 1
      		Sketchup;;set_status_text "[#{@tool_name}] Click corner #{@nextpointcount} of Polygon"
      		@status_text = "[#{@tool_name}] Click corner #{@nextpointcount} of Polygon"
      	else
      		# Final point picked
              	self.calculate_obj
              	Sketchup.active_model.select_tool(nil)
      def calculate_obj
      	# Check units of template again
      	lengthconstant = Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]
       	if (lengthconstant == 0) || (lengthconstant == 1)
      		@Unitstemplate2 = "imperial"
      	else
      		@Unitstemplate2 = "metric"
      	if @Unitstemplate2 == "metric"
      		# Sketchup;;set_status_text "Foundation Width; #{@BuildingSpan_m.round(4)} m - Foundation Length; #{@BuildingLength_m.round(4)} m"
      	else
      		# Sketchup;;set_status_text "Foundation Width; #{@BuildingSpan_ft.round(4)} ft. - Foundation Length; #{@BuildingLength_ft.round(4)} ft."
      	MedeekMethods.main_menu_polygon @pts, @pointcount
      def onCancel(flag, view)
          reset
      def onUserText(text, view)
          # The user may type in something that we can't parse as a length
          # so we set up some exception handling to trap that
          begin
              value = text.to_l
          rescue
              # Error parsing the text
              UI.beep
              value = nil
              Sketchup;;set_status_text "", SB_VCB_VALUE
          return if !value
          case @state
          when STATE_PICK_NEXT
              # update the width
              vec = @pts[1] - @pts[0]
              if( vec.length > 0.0 )
                  vec.length = value
                  @pts[1] = @pts[0].offset(vec)
                  view.invalidate
                  self.update_state
          when STATE_PICK_LAST
              # update the height
              vec = @pts[3] - @pts[0]
                  vec.length = value
                  @pts[2] = @pts[1].offset(vec)
                  @pts[3] = @pts[0].offset(vec)
                  self.update_state
      def getExtents
          bb = Geom;;BoundingBox.new
          case @state
          when STATE_PICK
              # We are getting the first point
              if( @ip.valid? && @ip.display? )
                  bb.add @ip.position
          when STATE_PICK_2
              bb.add @pts[0]
              bb.add @pts[1]
          when STATE_PICK_3
              bb.add @pts[2]
      	bb.add @pts
          return bb
      def onKeyDown(key, rpt, flags, view)
          if( key == CONSTRAIN_MODIFIER_KEY && rpt == 1 )
              @shift_down_time = Time.now
              # if we already have an inference lock, then unlock it
              if( view.inference_locked? )
                  view.lock_inference
              elsif( @state == 0 )
                  view.lock_inference @ip
              elsif( @state == 1 )
                  view.lock_inference @ip, @ip1
      	elsif( @state == 2 )
      	elsif( @state == 3 )
      	elsif( @state == 4 )
      def onKeyUp(key, rpt, flags, view)
              view.inference_locked? &&
              (Time.now - @shift_down_time) > 0.5 )
              view.lock_inference
      # draw a polygon for the outline of the foundation
      def draw(view)
          @drawn = false
          # Show the current input point
              @ip.draw(view)
              @drawn = true
          case @state
          when STATE_PICK
              # do nothing
          when STATE_PICK_2
              # just draw a line from the start to the end point
              view.set_color_from_line(@ip1, @ip)
      	view.drawing_color = [0, 0, 200]
              inference_locked = view.inference_locked?
      	view.line_width = 2 if inference_locked
      	view.line_width = 2
              view.draw(GL_LINE_STRIP, @pts[0], @pts[1])
              @drawn = true
          else
      	# view.set_color_from_line(@ip1, @ip)
      	view.line_width = 2
              view.draw(GL_LINE_STRIP, @pts)
              @drawn = true
      end # class PositionToolPolygon
      end # module FoundationPositionToolPolygon
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • Dan RathbunD Offline
        Dan Rathbun
        Pls edit and remove code, then re-post properly indented code in a [ code ] ... [ /code ] block.
        (Ie, no one will even attempt to read it.)
        I'm not here much anymore.
        • medeekM Offline
          medeek
          Hopefully that is a bit better.
          design.medeek.com
          • medeekM Offline
            medeek
            What would be useful is if I could somehow constrain the line angle (or snap to) to 15 degree increments. Has anyone ever tried to do something like this?
            design.medeek.com
            • Rich O BrienR Online
              Fredo's DrawAlong tool in Fredo Tools snaps to increments.
                Dan Rathbun
                You would basically save the user's current angle snap settings, set 15 degrees and angle snap ON, do your thing, then restore the user's settings.
                At the least you should honor the user's settings (perhaps as a starting point.)
                Access via Sketchup::Model#options(), ie:
                model = Sketchup.active_model
                manager = model.options
                manager.each {|key| puts "#{key.name}" }
                #=> PageOptions
                #=> UnitsOptions
                #=> SlideshowOptions
                #=> NamedOptions
                #=> PrintOptions
                opts = manager["UnitsOptions"]
                #=> #<Sketchup;;OptionsProvider;0x00000009215148>
                opts.each {|key,name| puts "#{key} = #{name}" }
                #=> LengthPrecision = 3
                #=> LengthFormat = 0
                #=> LengthUnit = 0
                #=> LengthSnapEnabled = true
                #=> LengthSnapLength = 0.0001
                #=> AnglePrecision = 1
                #=> AngleSnapEnabled = true
                #=> SnapAngle = 15.0
                #=> SuppressUnitsDisplay = false
                #=> ForceInchDisplay = false
                so:
                def save_angle_options(model=Sketchup;;active_model)
                  opts = model.options["UnitsOptions"]
                  opts["AngleSnapEnabled"], opts["SnapAngle"]
                def restore_angle_options(snapping,angle,model=Sketchup;;active_model)
                  opts["AngleSnapEnabled"]= snapping
                  opts["SnapAngle"]= angle
                # In code elsewhere;
                snapping, angle = save_angle_options()
                # do your thing
                restore_angle_options(snapping,angle)
                • medeekM Offline
                  medeek
                  Even when I'm drawing a line with the built in tools the angle snapping in SketchUp doesn't seem to work, what am I missing here?
                  design.medeek.com
                    Dan Rathbun
                    Angle snapping works for rotational tools or tool states.
                    Length snapping would work for linear tool states.
