    Final Documentation for BakeHouse Distillery
    27 Posts 14 Posters 3.6k Views 14 Watching
    • RichardR Offline
      Richard
      Phew now final I can post the finished after a few months in design, documentation and the writing of a 70 page planning report to support the application.
      BIG JOB! The proposal contains:
      DEMONSTRATION GIN DISTILLERY,
      RESTAURANT,
      RECEPTION CENTRE,
      MANAGER'S RESIDENCE,
      COMMERCIAL LAUNDRY, and
      15 TOURIST CHALETS
      The development is within a sensitive Drinking Water Catchment, so we have had to employ the use several modern Aerobic Treatment Units to pretreat wastewater before on-site disposal. This on-site disposal of wastewater actually helps as we are also in a High Risk Bushfire, we essentially keep wet all vegetation surrounding the development, lowering its flammability.
      The site is located within an established "rural agriculture | rural production area" so the intent of overall styling is to project built forms as "repurposed" from those expected in a predominantly rural area.
      AND now the fingers are crossed that we have demonstrated a well considered, well addressed proposal that can be supported through assessment!
      This thread is a pretty much an update of a previous, posted to display the "early concept".
      http://sketchucation.com/forums/viewtopic.php?f=81%26amp;t=66083
      Other than utilising Indesign to create shadows to the PDF exported from Layout, ALL docs were produced directly in Layout, IE: All floor plans, site plans and annotations. SketchUp was used for modeling and export of rendered elevations which were imported to Layout as images.
      Layout | SketchUp | Maxwell | Photoshop | Indesign
      Landscape Principles
      Site Analysis
      Schematic Layout 1:1000
      Schematic Layout 1:500
      Commercial Impression
      Commercial Lower Floor
      Commercial Upper Floor
      Commercial Elevations One
      Commercial Elevations Two
      Commercial Elevations Three
      Tourist Chalets Impression
      Chalet Clusters One
      Chalet Clusters Two
      Chalet Type 1
      Chalet Type 2A
      Chalet Type 2B
      Chalet Type 2C
      Entry Treatment One
      Entry Treatment Two
      BUILTBRAND.COM.AU
      • HornOxxH Offline
        HornOxx
        Actually I'm speechless but, as you see, obviously not πŸ˜„ πŸ˜‰ πŸ˜„
        Long before I think about presented contents, As allways, I'll stick to your outstanding good graphic language. Reduced to white-gray-black, combined with a clear color coding using mainly orange as a matching contrast color for your there pointed(?) references. This "language" you hold through all the plans and everything, from start to end, is from one single font πŸ‘ πŸ‘
        Since this entire facility is probably too far away from the road to be seen from there, it is a good idea carefully to appreciate the driveway(?) with itΒ΄s own special design.
        Especially I love the "simplicity" to produce plasticity by the use of shadows (are the shadows made by layer syles PS?). In the plan "Landscape Principles" this effect is nice to look at, since this works very playfully, without any strictness.
        never trust a skinny cook
        • jo-keJ Offline
          jo-ke
          HornOxx ist totally right.
          Outstanding as always. Beautyfull presentation
          http://www.zz7.de
          • K Offline
            kaas
            Great assignment, great design, great presentation... Great job!
            • cottyC Offline
              cotty
              A real Richard!
              Great (again)!
              my SketchUp gallery
              • andybotA Offline
                andybot
                Beautiful work, great job!
                • pbacotP Offline
                  Masterpiece of presentation and documentation! Congratulations!
                  • tademaT Offline
                    tadema
                    Hello Richard, nothing I can say that has not already been said above. Clients often fail to realise the amount of work goes into these type of presentations. Beautiful πŸ‘ πŸ‘ πŸ‘
                    John
                    • RichardR Offline
                      Richard
                      Thank you SO MUCH for the praise mate!!!!!! πŸ‘
                      To answer your question:
                      @hornoxx said:
                      Especially I love the "simplicity" to produce plasticity by the use of shadows (are the shadows made by layer styles PS?).
                      To keep the whole page sharp and text legible I've used Indesign to get the shadow effects for the trees. Everything on the page was compiled in Layout and exported as a layer enabled PDF.
                      The trees are on 3 separate layers within that PDF. Within Indesign the PDF is dragged onto a page, all tree layers turned off so all background elements only are displayed, this is then copied > pasted in place and just level one trees enabled and shadow cast added > pasted in place again and just level two trees enabled and shadow cast added > and again for level three trees. The whole document then exported out as a PDF.
                      The result is much cleaner and lighter (file size) wise as kept as vectors.
                      Again, big thanks mate!
                      BUILTBRAND.COM.AU
                      • RichardR Offline
                        Richard
                        Thanks mate, I'm hoping the Council assessing the application for it clear and legible!
                        BUILTBRAND.COM.AU
                        • RichardR Offline
                          Richard
                          Thank you my man! Seriously fun design job, certainly a lot of time spent fully considering all aspects to get what I hope will be a successful venture. And keep me stocked with Gin!!!
                          BUILTBRAND.COM.AU
                          • RichardR Offline
                            Richard
                            @cotty said:
                            A real Richard!
                            Great (again)!
                            Cheers mate! I'm now hoping for an approval so I can jump onto some marketing work to promote the final product!
                            BUILTBRAND.COM.AU
                            • RichardR Offline
                              Richard
                              Thanks mate! Its been a big job, just writing the report took weeks of research and writing itself!
                              BUILTBRAND.COM.AU
                              • RichardR Offline
                                Richard
                                Thank you as always kind sir!!!!! πŸ‘
                                BUILTBRAND.COM.AU
                                • RichardR Offline
                                  Richard
                                  John
                                  Luckily in this case mate the client has been so involved with the whole design and documentation he is rather struck by the work that has gone into it!
                                  And luckily for all of US here, the tools at our disposal are well up to the task of producing great stuff!!!
                                  BUILTBRAND.COM.AU
                                  • cheddaC Offline
                                    chedda
                                    A comprehensive submission, very easy to read and understand.
                                    Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                                    • RichardR Offline
                                      Richard
                                      Thank you ma man!!!!
                                      BUILTBRAND.COM.AU
                                      • marked001M Offline
                                        marked001
                                        These are awesome, richard. I am in love with that first landscape plan.
                                        http://www.revision21vis.com
                                        instagram: revi21on
                                        • RichardR Offline
                                          Richard
                                          Cheers mate! I particularly like the method to convey the site's slope. Its just the contours chopped up and joined to create an object. Then given all the same fill and then transparency dropped by 5% for each object.
                                          BUILTBRAND.COM.AU
                                            Very fine as always! 😎
                                            Have you try the Affinity serial programs who seems have a very agressive price against Adobe ones?
                                            • 1 / 2
