Insert Picture into excel
This code works fine by itself:
model = Sketchup.active_model entities = model.active_entities view = model.active_view status = view.write_image "test.jpeg" keys = { ;filename => "S;/Stairs/Stair Pics/write_image.jpeg", ;width => 500, ;height => 400, ;antialias => false, ;compression => 0.5, ;transparent => false } model = Sketchup.active_model view = model.active_view new_view = view.zoom_extents view.write_image keysand this works fine by itself:
require 'win32ole' xl = WIN32OLE.new('Excel.Application') xl.visible=1 wb = xl.Workbooks.Open('C;\TestFolder\Test2.xlsx') worksheet = wb.Worksheets('Sheet1') worksheet2 = wb.Worksheets('Sheet2') worksheet.Range('a1').Value=12 worksheet.Range('a1;b4').Value #-----Pictures Insert Code--------------- pic = worksheet2.Pictures.Insert('S;\Stairs\Stair Pics\Fellner-Landing.JPG') range = worksheet2.Range('A1;F15') pic.ShapeRange.LockAspectRatio = false pic.Top = range.Top pic.Left = range.Left pic.Width = range.Width pic.Height = range.HeightI want to save the image then insert it into Excel.
-My idea was to save the image, then insert that saved image into excel.
The code does not like the jpeg file S:/Stairs/Stair Pics/write_image.jpeg, it will insert any other pic except the one that was created with the code above.require 'win32ole' model = Sketchup.active_model entities = model.active_entities view = model.active_view # Puts in SketchUp install directory by default status = view.write_image "test.jpeg" keys = { ;filename => "S;/Stairs/Stair Pics/write_image.jpeg", ;width => 500, ;height => 400, ;antialias => false, ;compression => 0.5, ;transparent => false } model = Sketchup.active_model view = model.active_view new_view = view.zoom_extents view.write_image keys #------------------------------------ xl = WIN32OLE.new('Excel.Application') xl.visible=1 wb = xl.Workbooks.Open('C;\TestFolder\Test2.xlsx') worksheet = wb.Worksheets('Sheet1') worksheet2 = wb.Worksheets('Sheet2') worksheet.Range('a1').Value=12 worksheet.Range('a1;b4').Value #-----Pictures Insert Code--------------- pic = worksheet2.Pictures.Insert('S;/Stairs/Stair Pics/write_image.jpeg') range = worksheet2.Range('A1;F15') pic.ShapeRange.LockAspectRatio = false pic.Top = range.Top pic.Left = range.Left pic.Width = range.Width pic.Height = range.Height -
Does the Excel app want \ separators.
Try swapping / for \ so:
pic = worksheet2.Pictures.Insert('S:/Stairs/Stair Pics/write_image.jpeg')
becomes
pic = worksheet2.Pictures.Insert('S:\Stairs\Stair Pics\write_image.jpeg') -
(1) Only write to paths that the user has write permissions on.
@davesexcel said:
# Puts in SketchUp install directory by defaultThis path is a binary program path and the normal user does not have write permissions there.
This is not the default path for Ruby when SketchUp v13+ is running. After SketchUp loads Ruby and it's API, it sets the working directory to the User's "Documents" directory.
SketchUp 2013 and higher:
Dir.pwd %(green)[#=> C:/Users/Dan/Documents]SketchUp 8 and earlier just left the current working directory in SketchUp's program path (which was a bad thing.)
(2) In code when you are doing a write then read, you need to wait until the file is finished being written, and the OS file system advertises that it is "ready" and available. (ie, the old file handle is closed.)
The Ruby standard
Fileclass has some class methods to help you determine if paths are readable or writable by the current user, and whether the OS reports if the file is finished being written (ie, does it exist yet?)def image_from_model( write_path = 'S;/Stairs/Stair Pics/', keys = { ;filename => 'write_image.jpeg', ;width => 500, ;height => 400, ;antialias => false, ;compression => 0.5, ;transparent => false } ) return false unless File.writable?(write_path) image_path = File.join( write_path, keys[;filename] ) keys[;filename]= image_path model = Sketchup.active_model view = model.active_view view.zoom_extents Kernel.sleep(2.0) # wait for view to redraw view.write_image(keys) @tid = UI.start_timer(0.5,true) { if File.exist?(image_path) UI.stop_timer(@tid) insert_to_excel(image_path) end } end def insert_to_excel() xl = WIN32OLE.new('Excel.Application') xl.visible=1 wb = xl.Workbooks.Open('C;\TestFolder\Test2.xlsx') worksheet = wb.Worksheets('Sheet1') worksheet2 = wb.Worksheets('Sheet2') worksheet.Range('a1').Value=12 worksheet.Range('a1;b4').Value #-----Pictures Insert Code--------------- pic = worksheet2.Pictures.Insert('S;/Stairs/Stair Pics/write_image.jpeg') range = worksheet2.Range('A1;F15') pic.ShapeRange.LockAspectRatio = false pic.Top = range.Top pic.Left = range.Left pic.Width = range.Width pic.Height = range.Height # write done message to SketchUp console; put "Finished inserting image in Excel." end
Register LoginAdvertisement
