    Insert Picture into excel
    3 Posts 3 Posters 949 Views 3 Watching
      davesexcel
      This code works fine by itself:
       model = Sketchup.active_model
       entities = model.active_entities
       view = model.active_view
       status = view.write_image "test.jpeg"
       keys = {
         ;filename => "S;/Stairs/Stair Pics/write_image.jpeg",
         ;width => 500,
         ;height => 400,
         ;antialias => false,
         ;compression => 0.5,
         ;transparent => false
       new_view = view.zoom_extents
       view.write_image keys
      and this works fine by itself:
      require 'win32ole'
      xl = WIN32OLE.new('Excel.Application')
      xl.visible=1
      wb = xl.Workbooks.Open('C;\TestFolder\Test2.xlsx')
      worksheet = wb.Worksheets('Sheet1')
      worksheet2 = wb.Worksheets('Sheet2')
      worksheet.Range('a1').Value=12
      worksheet.Range('a1;b4').Value
      #-----Pictures Insert Code---------------
      pic = worksheet2.Pictures.Insert('S;\Stairs\Stair Pics\Fellner-Landing.JPG')
      range = worksheet2.Range('A1;F15')
      pic.ShapeRange.LockAspectRatio = false
      pic.Top = range.Top
      pic.Left = range.Left
      pic.Width = range.Width
      pic.Height = range.Height
      I want to save the image then insert it into Excel.
      -My idea was to save the image, then insert that saved image into excel.
      The code does not like the jpeg file S:/Stairs/Stair Pics/write_image.jpeg, it will insert any other pic except the one that was created with the code above.
       require 'win32ole'
       # Puts in SketchUp install directory by default
       keys = {
         ;width => 500,
         ;height => 400,
      xl.visible=1
      pic = worksheet2.Pictures.Insert('S;/Stairs/Stair Pics/write_image.jpeg')
      pic.Top = range.Top
        Does the Excel app want \ separators.
        Try swapping / for \ so:
        pic = worksheet2.Pictures.Insert('S:/Stairs/Stair Pics/write_image.jpeg')
        becomes
        pic = worksheet2.Pictures.Insert('S:\Stairs\Stair Pics\write_image.jpeg')
        • Dan RathbunD
          Dan Rathbun
          (1) Only write to paths that the user has write permissions on.
          This path is a binary program path and the normal user does not have write permissions there.
          This is not the default path for Ruby when SketchUp v13+ is running. After SketchUp loads Ruby and it's API, it sets the working directory to the User's "Documents" directory.
          SketchUp 2013 and higher:
          Dir.pwd %(green)[#=> C:/Users/Dan/Documents]
          SketchUp 8 and earlier just left the current working directory in SketchUp's program path (which was a bad thing.)
          (2) In code when you are doing a write then read, you need to wait until the file is finished being written, and the OS file system advertises that it is "ready" and available. (ie, the old file handle is closed.)
          The Ruby standard File class has some class methods to help you determine if paths are readable or writable by the current user, and whether the OS reports if the file is finished being written (ie, does it exist yet?)
          def image_from_model(
            write_path    = 'S;/Stairs/Stair Pics/',
            keys = {
              ;filename    => 'write_image.jpeg',
              ;width       => 500,
              ;height      => 400,
            return false unless File.writable?(write_path)
            image_path = File.join( write_path, keys[;filename] )
            keys[;filename]= image_path
            view.zoom_extents
            Kernel.sleep(2.0) # wait for view to redraw
            view.write_image(keys)
            @tid = UI.start_timer(0.5,true) {
              if File.exist?(image_path)
                UI.stop_timer(@tid)
                insert_to_excel(image_path)
          def insert_to_excel()
            xl.visible=1
            pic.Top = range.Top
            # write done message to SketchUp console;
            put "Finished inserting image in Excel."
          I'm not here much anymore.
