    Realtime ArchViz: SketchUp to Unity Workflow
    22 Posts 8 Posters 7.1k Views 8 Watching
    • chippwaltersC
      chippwalters
      Hey guys,
      I've been tasked to create a VR design lab for an east coast consumer products company. So, I've had to dive into some interesting topics, including creating low poly models and scenes which render in real time on the Vive. The goal is people being able to walk around and "touch" the products.
      One of the pipelines I'm working with is SketchUp direct import in Unity-- then setting it up as close to photoreal as I can. While I'm no Unity expert, I have covered quite a bit of ground in a short time and created these 4 videos to explain my workflow.
      Also, I know UE4 has a better renderer, but the learning curve is significant and the workflow can be much more difficult. Plus, Octane has announced a baker for Unity which should be released sometime this quarter which should make things much more interesting!
      Here's the collection of videos:
      Currently working with Cross-Reality technologies
      • PixeroP
        Pixero
        Thanks for the videos. I will take a look as soon as I can.
        • K
          kaas
          +1, I'm very curious about your workflow
          • chippwaltersC
            chippwalters
            Unity has a very nice INSTANCER called Prefabs and I used it to create a very quick 'space corridor' type of model. Here are a few renders using the technique described in Part 4. There's only ONE area light at the end of the corridor. The rest is lit by the emissive textures.
            https://dl.dropboxusercontent.com/u/3788438/3D/Corridor14.jpg
            https://dl.dropboxusercontent.com/u/3788438/3D/Corridor22.jpg
            https://dl.dropboxusercontent.com/u/3788438/3D/Corridor21.jpg
            https://dl.dropboxusercontent.com/u/3788438/3D/Corridor19.jpg
            https://dl.dropboxusercontent.com/u/3788438/3D/Corridor13.jpg
            https://dl.dropboxusercontent.com/u/3788438/3D/Corridor07.jpg
            • K
              kaas
              Interesting video's. Never had seen Unity in action - I use Unreal myself.
              Have you tried importing more blobby stuff into Unity (like sofa's with cushions?). Would be interesting to see if Unity still can make good lightmaps for that. With Unreal, blobby stuff, straight from SketchUp, results in artifacts in lightmaps - even with high settings. The only solution is to add a Lightmap channel in Blender.
              • chippwaltersC
                chippwalters
                Yep. That's a really good point. I too have had trouble importing files into UE4. FWIW, I use 3Dcoat to automatically UV map SketchUp models when I need to. It has a really fast mapping algorithm that generates pretty high-quality maps for any type of obj.
                I'll have to test.
                • M
                  measuredmove
                  Great tutorial-thanks!
                  I've been a user of Lightup https://www.light-up.co.uk for a number of years for rendering and rendered animations. I remember saving these links as something to look into at some future date to be able to import a fully lit and rendered SU file into Unity
                  The info is quite old but may still be viable......
                  Video: https://www.youtube.com/watch?v=eNI2RjNsRwY
                  Import Script: http://www.light-up.co.uk/forum/viewtopic.php?f=2%26amp;t=403
                  Unfortunately, there hasn't been alot of support on the Forums lately but if this is still a workable option (SU-Lightup-Unity) perhaps users can answer any questions.
                  Cheers
                  My 3D Catalogue
                  https://3dwarehouse.sketchup.com/collection/103ed44c-a0c4-4049-9a84-89cd017bcc07/Measured-Move
                  SU8/Brighter3D/Gimp/SimLab Composer
                  • chippwaltersC
                    chippwalters
                    So, I've been learning more about the SketchUp > Unity workflow. Lots of interesting possibilites. The new UV Mapping program, WrapR looks to be of great help in getting mappable UVs into Unity.
                    Another thing of interest is the fact Unity has a direct SU import capability-- though it's only updated to SU2015 necessitating you 'Save As' a 2015 version. The really cool part is it appears SU is ideally suited for creating low poly models for the following reasons:
                    1. SU by nature is a low poly modeler unless you're doing SDS.
                    2. SU has terrific vertex smoothing and it's WYSIWYG so it displays great in Unity. This is a problem for some other programs export of OBJ
                    3. Unity has a restriction of 65K polys per object, which works well with SU as it's not that often one group or component has 65K.
                      Unfortunately, Unity doesn't treat SU Components as Unity Prefabs (their instancing terminology), but they do have vertex snapping so it is possible to import a single SU Component and instance it (including mirroring) to specified locations.
                    More to follow..
                    • JQLJ
                      JQL
                      Have you ever heard of Playup tools? Export from sketchup to the main game engines.
                      www.casca.pt
                      Visit us on facebook!
                      • chippwaltersC
                        chippwalters
                        Thanks for sharing. Quick look tells me is really more of a UE4 tool than Unity. Unity has pretty nice support for SU whereas UE4 has lots of trouble importing SU native (at least it did a year ago when I last tried).
                        • chippwaltersC
                          chippwalters
                          Hey guys,
                          Back on the PBR to Unity pipeline and workflow. Spent tonight documenting the sum of what I’ve figured out so far in three videos:
                          1. How to build and quickly UV map in SketchUp for Unity
                          2. How materials work in Unity (not the way you might think they do).
                          3. How to create your own PBR textures and materials from pictures you take on your phone or files you find online
                          Some of the images I knocked out tonight for the tute:
                          https://dl.dropboxusercontent.com/u/3788438/AltuitNew/VRDemos/MaterialsTute/screen_4472x2514_2017-03-24_01-32-40.jpg
                          https://dl.dropboxusercontent.com/u/3788438/AltuitNew/VRDemos/MaterialsTute/screen_4472x2514_2017-03-24_01-31-48.jpg
                          https://dl.dropboxusercontent.com/u/3788438/AltuitNew/VRDemos/MaterialsTute/screen_4472x2514_2017-03-24_01-34-01.jpg
                          https://dl.dropboxusercontent.com/u/3788438/AltuitNew/VRDemos/MaterialsTute/screen_4472x2514_2017-03-24_00-14-58.jpg
                          And here are the videos:
                            Astonishing that programs can make! (and humans)! 😉
                            • K
                              kaas
                              Interesting to see your process & Unity (just saw the first video). Looking forward viewing the other two.
                                Ps Protrude by Jim is cool, but Joint PushPull can makes the same! 😉
                                Else Protrude is very cool for the randomize panelling!
                                (+ Lattice Maker by Tig) (+ FredoScale)
                                • chippwaltersC
                                  chippwalters
                                  Monsieur Pilou! Thanks for sharing. Didn't know that. Did you use Fredo scale to make the curved geometry? Also what to do you use to make your GIFs?
                                  • JonFarJ
                                    JonFar
                                    sorry for my ignorance in the following questions, but I'm really interested in Unity and realtime rendering, even more after seeing that it's rather simple to import Sketchup models into it.
                                    But I would like to understand a couple of things before investing time/money in learning a new software.
                                    1. I know it all depends on the quality and personal preferences but, once you learn how to work with it, is it easy/quick to set up scenes? or is it complex (like rendering in VRay) and requires you to tweak a lot of options and test the lighting and stuff until you reach the desired results?
                                    2. Unity can export animations like walk around 2 minute movies, right? But what about interactive animations, the ones where the client can walk around using WASD and mouse. Does "the client" have to have a powerful GPU/CPU/RAM/etc to run it?
                                    thanks for the help
                                      @Chipp
                                      Yes of course! 😄
                                      The nifty free GifCam 😉
                                      • chippwaltersC
                                        chippwalters
                                        Yes and no. The application of materials is pretty straightforward. Lighting is too, if you're outside. If inside, you'll need to add different lights such as light portals around windows (see my videos). Unity 5.6 has a new progressive lightmapper which makes it faster to set up lighting as you get a pretty fast read. The most cumbersome part is doing the final 'bake' for lighting, which can take up to several hours, once everything is set up.
                                        @jonfar said:
                                        1. Unity can export animations like walk around 2 minute movies, right? But what about interactive animations, the ones where the client can walk around using WASD and mouse. Does "the client" have to have a powerful GPU/CPU/RAM/etc to run it?
                                        Of course. Once you bake your lighting, it's easy to navigate and should not take any special computer to be able to navigate WASD your scene.
                                          @Chipp
                                          And the animation itself was just using the incredible LightUp! 😎
                                          • S
                                            sipi_2
                                            Hi!
                                               These tutorials are very helpful, it helped me a lot, thank you very much!
                                            I also use SketchUp and Unity to prepare my thesis. And with your tutorials my game looks much better now than it was 1 year ago!
                                            I'd like to ask for advice, I just discovered a new problem.
                                            As a thesis, I make a 3D labyrinth game (for testing path search algorithms) and it is made up of 20X20 meter models (actually prefabs). If I put only few models in the scene, it will bring about 60 fps. But in more than 20 models, I get extreme fps drops if the camera is in the direction of a large number of models. All this despite the fact that there is a wall between them. But overall, they lose a lot of fps.
                                            That is why I tested my models in an empty project without all kinds of effects, textures and lighting.Only SketchUV and basic Sketchup textures remained on them.
                                            First I put 1 model into the scene and it's got about 90 fps. The same applies to the 4 models.
                                            But in 10 models, it was only 70 fps. For the 30 models it dropped to 40 fps.
                                            The problem is that I need about at least 200 prefabs per scene, but rather more.
                                            What could be the problem?
                                            My config:
                                            CPU: Intel i5-3470 3.20 GHz
                                            RAM: 20 GB DDR3
                                            GPU: Radeon 6570 1 GB DDR3
                                            The video card is pretty weak, but I think this pair of models should just endure.
                                            I'm sorry, my English is not the best ...
                                            Thanks in advance!
                                            • 1 / 2
