    Realtime ArchViz: SketchUp to Unity Workflow
    22 Posts 8 Posters 7.1k Views 8 Watching
    • chippwaltersC
      chippwalters
      Thanks for sharing. Quick look tells me is really more of a UE4 tool than Unity. Unity has pretty nice support for SU whereas UE4 has lots of trouble importing SU native (at least it did a year ago when I last tried).
      Currently working with Cross-Reality technologies
      • chippwaltersC
        chippwalters
        Hey guys,
        Back on the PBR to Unity pipeline and workflow. Spent tonight documenting the sum of what Iโ€™ve figured out so far in three videos:
        1. How to build and quickly UV map in SketchUp for Unity
        2. How materials work in Unity (not the way you might think they do).
        3. How to create your own PBR textures and materials from pictures you take on your phone or files you find online
        Some of the images I knocked out tonight for the tute:
        https://dl.dropboxusercontent.com/u/3788438/AltuitNew/VRDemos/MaterialsTute/screen_4472x2514_2017-03-24_01-32-40.jpg
        https://dl.dropboxusercontent.com/u/3788438/AltuitNew/VRDemos/MaterialsTute/screen_4472x2514_2017-03-24_01-31-48.jpg
        https://dl.dropboxusercontent.com/u/3788438/AltuitNew/VRDemos/MaterialsTute/screen_4472x2514_2017-03-24_01-34-01.jpg
        https://dl.dropboxusercontent.com/u/3788438/AltuitNew/VRDemos/MaterialsTute/screen_4472x2514_2017-03-24_00-14-58.jpg
        And here are the videos:
          Astonishing that programs can make! (and humans)! ๐Ÿ˜‰
          • K
            kaas
            Interesting to see your process & Unity (just saw the first video). Looking forward viewing the other two.
              Ps Protrude by Jim is cool, but Joint PushPull can makes the same! ๐Ÿ˜‰
              Else Protrude is very cool for the randomize panelling!
              (+ Lattice Maker by Tig) (+ FredoScale)
              • chippwaltersC
                chippwalters
                Monsieur Pilou! Thanks for sharing. Didn't know that. Did you use Fredo scale to make the curved geometry? Also what to do you use to make your GIFs?
                • JonFarJ
                  JonFar
                  sorry for my ignorance in the following questions, but I'm really interested in Unity and realtime rendering, even more after seeing that it's rather simple to import Sketchup models into it.
                  But I would like to understand a couple of things before investing time/money in learning a new software.
                  1. I know it all depends on the quality and personal preferences but, once you learn how to work with it, is it easy/quick to set up scenes? or is it complex (like rendering in VRay) and requires you to tweak a lot of options and test the lighting and stuff until you reach the desired results?
                  2. Unity can export animations like walk around 2 minute movies, right? But what about interactive animations, the ones where the client can walk around using WASD and mouse. Does "the client" have to have a powerful GPU/CPU/RAM/etc to run it?
                  thanks for the help
                    @Chipp
                    Yes of course! ๐Ÿ˜„
                    The nifty free GifCam ๐Ÿ˜‰
                    • chippwaltersC
                      chippwalters
                      Yes and no. The application of materials is pretty straightforward. Lighting is too, if you're outside. If inside, you'll need to add different lights such as light portals around windows (see my videos). Unity 5.6 has a new progressive lightmapper which makes it faster to set up lighting as you get a pretty fast read. The most cumbersome part is doing the final 'bake' for lighting, which can take up to several hours, once everything is set up.
                      @jonfar said:
                      1. Unity can export animations like walk around 2 minute movies, right? But what about interactive animations, the ones where the client can walk around using WASD and mouse. Does "the client" have to have a powerful GPU/CPU/RAM/etc to run it?
                      Of course. Once you bake your lighting, it's easy to navigate and should not take any special computer to be able to navigate WASD your scene.
                        @Chipp
                        And the animation itself was just using the incredible LightUp! ๐Ÿ˜Ž
                          sipi_2
                          Hi!
                             These tutorials are very helpful, it helped me a lot, thank you very much!
                          I also use SketchUp and Unity to prepare my thesis. And with your tutorials my game looks much better now than it was 1 year ago!
                          I'd like to ask for advice, I just discovered a new problem.
                          As a thesis, I make a 3D labyrinth game (for testing path search algorithms) and it is made up of 20X20 meter models (actually prefabs). If I put only few models in the scene, it will bring about 60 fps. But in more than 20 models, I get extreme fps drops if the camera is in the direction of a large number of models. All this despite the fact that there is a wall between them. But overall, they lose a lot of fps.
                          That is why I tested my models in an empty project without all kinds of effects, textures and lighting.Only SketchUV and basic Sketchup textures remained on them.
                          First I put 1 model into the scene and it's got about 90 fps. The same applies to the 4 models.
                          But in 10 models, it was only 70 fps. For the 30 models it dropped to 40 fps.
                          The problem is that I need about at least 200 prefabs per scene, but rather more.
                          What could be the problem?
                          My config:
                          CPU: Intel i5-3470 3.20 GHz
                          RAM: 20 GB DDR3
                          GPU: Radeon 6570 1 GB DDR3
                          The video card is pretty weak, but I think this pair of models should just endure.
                          I'm sorry, my English is not the best ...
                          Thanks in advance!
                          • chippwaltersC
                            chippwalters
                            Please review occlusion culling:
                            https://docs.unity3d.com/Manual/OcclusionCulling.html
                              sipi_2
                              It works! I very thank you! ๐Ÿ˜„
