    Grooves on cylinder surface?
    Scheduled Pinned Locked Moved Organic Modelling
    7 Posts 3 Posters 13.8k Views 3 Watching
    • dragontechD Offline
      dragontech
      Before I even ask my question, THANK YOU!
      OK, so I have a cylinder shaped object and I want small grooves running up and down on the outside surface. Its the end cap for a nacelle. Is there a way to do this with the follow me tool or something? I could do it by hand, each groove, but being so small , I'd be in a nursing home by the time I finished, 🀣
      http://dragonlourde.deviantart.com/
      • cottyC Offline
        cotty
        One quick way without plugins...
        grooves.skp
        my SketchUp gallery
          dragontech
          [attachment=1:21aujd7l]<!-- ia1 -->grooves.JPG<!-- ia1 -->[/attachment:21aujd7l]
          Seriously.. Did you just do that to show me? You rock, either way. I have SU15 right now so it's not letting me open the file, (I need to upgrade I guess), so did you just draw the grooves?
          Thank you for this. Just might work. πŸ‘
          • cottyC Offline
            cotty
            Here's the file as version 8.
            grooves_v8.skp
            my SketchUp gallery
              dragontech
              @pbacot said:
              IDK just how he did the grooves, but you could for example, just use two edgs in a "v" set to a facet in the circle, the copy/rotate all around.
              I don't know how to do that but I'll check it out.
              • cottyC Offline
                cotty
                A little making-of...
                grooves3_v8.skp
                my SketchUp gallery
                • pbacotP Offline
                  IDK just how he did the grooves, but you could for example, just use two edgs in a "v" set to a facet in the circle, then copy/rotate all around.
