    Vray 3.4 beta
    renderpluginsextensions
    1 Posts 1 Posters 1.3k Views 1 Watching
    • I
      Isarescu
      I don`t like:
      -sometimes it renders a black screen. If I press render again, it works as it shold.
      -it renders hidden lights, or lights that are on a hidden layer.
      -setting the attributes with a slider instead of a number (reflexion for example)
      -the new icons
      -the fact that the vray materials are black in the model
      -the fact that when you want to save your render, .png is preselected, even after you use .jpg
      -if you start a 6:1 stereoscopic render and you check the "V-Ray swarm enable" box, the render is restarted as a normal one.
      -the "Failed to check ou V-ray gui license" error
      I like:
      -set camera focus button
      -6:1 stereoscopic render function (works great with Samsung Gear)
      -create fur button.
      What`s your opinion?
