    Select 'Flip along' from dynamic component options
    2 Posts 2 Posters 7.3k Views 2 Watching
    • S
      Softwaretester
      I want the user to be able to use the 'flip along' (red,green or blue) from the options list of a dynamic component.
      Is this possible using the dynamic component attributes?
      If not : can it be emulated?
      • TNTDAVIDT
        TNTDAVID
        Hello,
        In dimension attributes you must invert the dimensions from positive to negative.
        For a mirror on the X axis, LenX must change from 100 to -100 for example.
        See you soon
        David
