    Select 'Flip along' from dynamic component options
    Scheduled Pinned Locked Moved Dynamic Components
    2 Posts 2 Posters 7.2k Views 2 Watching
      Softwaretester
      I want the user to be able to use the 'flip along' (red,green or blue) from the options list of a dynamic component.
      Is this possible using the dynamic component attributes?
      If not : can it be emulated?
      • TNTDAVIDT Offline
        TNTDAVID
        Hello,
        In dimension attributes you must invert the dimensions from positive to negative.
        For a mirror on the X axis, LenX must change from 100 to -100 for example.
        See you soon
        David
        [b:8wt9py2i]* Nouveau !!![/b:8wt9py2i] Découvrez notre nouveau Plugin [url=http://www.composant-dynamique.com/:8wt9py2i][color=#40FF00:8wt9py2i]C[/color:8wt9py2i][color=#77FF00:8wt9py2i]l[/color:8wt9py2i][color=#ADFF00:8wt9py2i]i[/color:8wt9py2i][color=#E4FF00:8wt9py2i]c[/color:8wt9py2i][color=#FFDB09:8wt9py2i]k[/color:8wt9py2i][color=#FF921B:8wt9py2i]-[/color:8wt9py2i][color=#FF492E:8wt9py2i]C[/color:8wt9py2i][color=#FF0040:8wt9py2i]u[/color:8wt9py2i][color=#ED2577:8wt9py2i]i[/color:8wt9py2i][color=#DA49AD:8wt9py2i]s[/color:8wt9py2i][color=#C86EE4:8wt9py2i]i[/color:8wt9py2i][color=#AD77FF:8wt9py2i]n[/color:8wt9py2i][color=#8965FF:8wt9py2i]e[/color:8wt9py2i] [color=#4040FF:8wt9py2i]2[/color:8wt9py2i][/url:8wt9py2i], pour créer vos cuisines 3D !
