    Add icon to plugin
    3 Posts 2 Posters 499 Views 2 Watching
    • G
      Gonvaz
      I'm trying to add an icon to a plugin but I can't make it work and I see no errors on the Ruby Console. Can you help?
      Thanks in advance!
      require 'Sketchup'
      filename=File.basename(FILE)
      if not file_loaded?(filename)
      UI.menu('Plugins').add_item('Container creator') { JGV_FVC3.container_creator() }
      #Toolbar test
      if !file_loaded?("Container.rb")
      #Container creator toolbar
      FV_project_tb = UI::Toolbar.new("FV JGV")
      #Container creator command
      cmd3 = UI::Command.new(("Container creator")) { JGV_FVC3.container_creator() }
      cmd3.small_icon = "containersmall.png"
      cmd3.large_icon = "containerbig.png"
      cmd3.tooltip = "Inserts a container"
      FV_project_tb.add_item(cmd3)
      #End Toolbar test
      file_loaded(filename)
      module JGV_FVC3
      def self.container_creator
      • K
        kaas
        I think you need some extra lines to actually show your toolbar:
        require 'Sketchup'
        filename=File.basename(__FILE__)
        #Toolbar test
        	FV_project_tb = UI;;Toolbar.new("FV JGV")
        	cmd3 = UI;;Command.new(("Container creator")) { JGV_FVC3.container_creator() }
        	if FV_project_tb.get_last_state==TB_NEVER_SHOWN
        		FV_project_tb.show
        	elsif FV_project_tb.get_last_state==TB_VISIBLE
        		FV_project_tb.restore
        #End Toolbar test
        • G
          Gonvaz
          Thanks kaas. It works like a charm.
