    2017 Selection tool is giving me the "blues"
    6 Posts 3 Posters 632 Views 3 Watching
    • davidmreinboldD Offline
      davidmreinbold
      Hi guys
      I don't know about you but I find it a huge step backwards that selected geometry is now turning solid blue. I am really having trouble seeing the benefit, in actual fact one cannot see anything at all through the solid mass of blue. It is really counter productive and somewhat annoying. ... can this be switched off? any ideas welcome... πŸ˜’
      SU 2016 geometry selection keeps outlines visible in X-Ray mode .... so useful
      SU 2017 geometry selection blocks the view with a solid mass of blue...
      • BoxB Offline
        That's not normal, at a guess I would say it is a Graphic Card issue.
        Check for a Driver update for your card.
          davidmreinbold
          Thanks Box, seems odd if it;s a graphics card issue as it still works fine in SU2016...
          So I take you don't have the same issue? I send a message to SU tech support... see what they have to say about this... will post the outcome here.
            I haven't seen this at all when I'm working in SU2017 and yours is the first report of it I've read. The graphics pipeline is entirely different in SU2017 from earlier versions so it is entirely likely it has to do with the graphics card/drivers on your machine. Try updating the drivers.
            What GPU do you have?
              davidmreinbold
              Hi Dave and Box, I have updated my graphics driver and 'hey presto' problem solved... thanks for your advice...
              Cheers David
                Now you'll have to find some other reason to sing the blues. Did you dog run off and leave you, maybe? πŸ˜„
