    Quick way to batch convert .jpg textures to .skm?
    3 Posts 3 Posters 2.3k Views 3 Watching
      CalypsoArt
      I've been trying to clean up the folders of my multiple SU materials. I have a couple from when SU used .jpgs for textures. I know the procedure through importing, but this is one by one. Is there a method to batch convert?
      • jujuJ Offline
        juju
        Have you had a look at TIG's SKM tools?
        Also take a look at Sam D Mitch's Image 2 model.
        And maybe @Last's Texture Writer.
        Also see Julia Christina Eneroth's Material Extractor.
        Depending on your workflow at the time, you may need to use a number of these in combination / succession.
          Jim
          There is an old one called massmaterialimporter which may work.
          I'm sure someone can update it if it does not.
          Edit - it stil works in 2017.
