Quick way to batch convert .jpg textures to .skm?
I've been trying to clean up the folders of my multiple SU materials. I have a couple from when SU used .jpgs for textures. I know the procedure through importing, but this is one by one. Is there a method to batch convert?
Have you had a look at TIG's SKM tools?
Also take a look at Sam D Mitch's Image 2 model.
And maybe @Last's Texture Writer.
Also see Julia Christina Eneroth's Material Extractor.
Depending on your workflow at the time, you may need to use a number of these in combination / succession.
There is an old one called massmaterialimporter which may work.
I'm sure someone can update it if it does not.
Edit - it stil works in 2017.
