    Disabling advanced camera tools causing error
    7 Posts 2 Posters 7.4k Views 2 Watching
    • halroachH
      halroach
      When disabling "Advanced Camera Tools" both in Sketchup 2015 and in 2016 (maybe further), it causes an undefined method error with scripts that use 'get_attributes' (with the S) on a component definition.
      The error:
      " Could not load xxx.rb:
      undefined method 'get_attributes' for
      #Sketchup::ComponentDefinition0x000000.... "
      I usually disable the 'Advanced Camera Tools' extension (It may cause all sorts of scene problems in some models), but I guess I'll have to live with this one when I want to run a certain script...
      1. Does this happen to anyone else?
      2. I can't seem to find 'get_attributes' (with the s) in the Sketchup API, nor in the Ruby Docs... ?
      Good Day
      Yoni
      FlexTools - Super Quick Windows, Doors, Slats...
      • D
        driven
        it's a Dynamic Components method...
        do you have a model and a code snippet that generates the error...
        john
        • halroachH
          halroach
          You can test it with your DC encrypter decrypter.
          • D
            driven
            I'll have a look, it was a test...
            ok I can reproduce it with a new model with any DC and this code...
                 m = Sketchup.active_model
                m.definitions.each do |d|
                  if defined? d.attribute_dictionaries
                  next unless d.attribute_dictionaries && d.attribute_dictionaries['dynamic_attributes']
                  if defined? d.get_attributes
                    p d.name
                    d.get_attributes('dynamic_attributes').each do |a|
                      p a
                 else
                   p d.name.upcase
                 end end end
            Run with ACT off and you get the UPCASED definition names, turn ACT on and run again, you get the list...
            I only tested on mac, v2017...
            it 'looks' like get attributes is defined in ACT...
            john
            • D
              driven
              it definitely part of ACT...
              and is the equivalent of this attribute_dictionaries['dynamic_attributes'].entries.to_h...
              proof:
                     p d.name
                     p d.attribute_dictionaries['dynamic_attributes'].entries.to_h == d.get_attributes('dynamic_attributes')
              solution:
              do a search and replace in any plugin that uses get_attributes('dynamic_attributes')... [untested]
              john
              • halroachH
                halroach
                Thanks John!
                That definitely clears up a lot of things I couldn't understand. 😄
                When I was analyzing your decrypter, 'get_attributes' fit in so well it looked like it's part of the API. Maybe it should be?!
                • D
                  driven
                  when I write 'quick and dirty' tests I tend to check for methods using Ruby :methods method...
                  that can expose 'undocumented' methods that I have no idea of the owner of...
                  I must of had ACT on when I first wrote this one [ I don't normally ]...
                  good thing you found it, I'll find and change my snippet...
                  john
