    Shape bender doesn't bend the shape as i want
    Scheduled Pinned Locked Moved Organic Modelling
    2 Posts 2 Posters 11.8k Views 2 Watching
    • E
      EeyoreKen
      i create a ramp and i'm going to bend it , but the result are not matching the curved.
      i've just get messed up geometry.
      http://imgur.com/ikgAdx3
      Ramp.skp
      • TIGT
        It is possible - see the screen-shot.
        I moved the red-axis line so it was easier to pick, and relocated the curve so that its start aligned with the line's start along the green-axis.
        The initial offering was a mess because the start/end clash, BUT using the down-arrow toggled that and the bent form looks OK to me ?
        It's also usually a good idea to make the line and the curve the same length - your curve is ~2.2m shorter, using Entity Info...
