    Layer Panel has diappeared
    layout
    7 Posts 6 Posters 4.8k Views 6 Watching
    • W
      whitelock
      My layers panel has disappeared in layout 2017 and i cant get it back by clicking on window-layers nothing happens. Is there a reset? Anyone else having massive problems with this program, every upgrade seems to get glitchier and glitchier
      [mod=Rich:1wox3uuz]Unshoutified post[/mod:1wox3uuz]
      • BoxB
        Is it hiding under your caps lock button....
        couldn't resist.
        Have you created a second tray and not just the Default tray. It could be opening on that. There should be a tab on the tray for more trays.
        • W
          whitelock
          I should say that I am using Layout 2017 on a mac, so the layers panel is normally floating on my second monitor. I don't think i have moved it into the edge of the monitor as that has happened before, but I can't see it anywhere. Is it possible to reset panels
          • W
            wolfram
            Same here. Pages panel and some others missing. SU 2017 on a Mac.
            I miss the "reset workspace" button of SketchUp...
            • bmikeB
              bmike
              I have this happen from time to time...
              I am using the app 'Moom' on my Mac to move / reset windows when I switch from 1-3 monitors.
              You can also for LO to arrange the panels...
              mike beganyi design + consulting llc
              • bazB
                baz
                It's still there...
                • F
                  fbennett
                  I've been having the same issue. My work around has been to collapse all other open trays and then toggle the green resize button - top left.
