    Is there a plugin to batch rename scenes?
    9 Posts 6 Posters 4.9k Views 6 Watching
      db11
      I have a SU model with dozens of scenes that I'd like to batch rename, in this case by replacing the "Scene" prefix (with a one or two letter appellation) and adding a sequential suffix from the current order.
      Is anyone aware of a plugin with that function β€” maybe one of Renderiza's?
      If not, would it be difficult/possible to write one?
      Thanks,
      Doug
        n=inputbox(["Prefix; "],["N"],"Scene_Rename");Sketchup.active_model.pages.each_with_index{|p,i|p.name="#{n[0]} #{i+1}"}if n;puts
        Copy+paste+enter this Ruby one-liner into the Ruby Console - it renames all scene-tabs in order with the 'Prefix' - e.g. 'N 1', 'N 2' etc...
        The dialog lets you type in any desired 'Prefix'...
        • F Offline
          function
          Thanks again TIG πŸ’š
            db11
            Thanks TIG.
            When I had time last night I went back to look at Rederiza's ReScene and it does have a rename function.
            It's very slow to load though (at least on a Mac), so your one-liner will be useful.
            Is there a (simple) way to modify it to rename only selected scenes?
              Ludolff
              Hi TIG, Many thanks for this code. Is there anyway of adding some code to this that will allow you to select the scenes to rename?
              Ludolff
                You can only select scenes that have names matching a pattern...
                Let's say you want to rename only prefixed scenes containing the text 'Plan', you need to enter an extra option...
                n = inputbox( ["Prefix; ", "Pattern; "], ["N", "Plan"], "Scene_Rename" ); Sketchup.active_model.pages.each_with_index{|p, i| (p.name = "#{n[0]} #{i+1}") if p.name =~ /#{n[1]}/ } if n; puts
                BUT you need to decide on the 'pattern' !
                  StarSketch
                  Thank you a lot TIG, you save my day !!! πŸ‘ πŸ‘
                  • onzkiO Offline
                    onzki
                    Thank you TIG! Is there a way to rename using filter/ conditions? Example I have time scene names, like Scene 1 10:00am, Scene 2 1:00pm, Scene 3 6:00pm, (etc.. lots of it)
                    I want to rename all time to use 24-hour military time convention. Is it possible? So all with "10:00am" becomes-> 1000. Same goes with others.
                    Thanks!
                    [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
                      You need to add some extra code, e.g.
                      read the scene name
                      then split it at the space etc etc
                      name="Scene 2 1;00pm"
                      splitname=name.split(" ") ###>>> ["Scene", "2", "1;00pm"]
                      timestring = splitname[2] ###>>> "1;00pm"
                      ###delete the ;
                      timestring.gsub!(/[;]/, "") ###>>> "100pm"
                      ###now check if pm
                      if timestring=~/pm$/
                        timestring.gsub!(/pm$/, "")
                        time_num=timestring.to_i + 1200 ###>>> 100 >>> 1300
                        timestring=time_num.to_s
                      elsif timestring=~/am$/
                        timestring.gsub!(/am$/, "") ###>>> 100
                      name=splitname[0]+" "+splitname[1]+" "+timestring ### modify name >>> "Scene 2 1300"
                      ### now rename that scene with the modified name etc...
                      To strip off the entire 'Scene N ' part just use:
                      name=timestring ### modify name >>> "Scene 2 1;00pm" >>> "1300"
