    SketchUp 2017 - Warning Dynamic Components
    3 Posts 2 Posters 2.5k Views 2 Watching
    • TNTDAVIDT Offline
      TNTDAVID
      The installation of SketchUp 2017 no longer allows the use of dynamic components on older versions of SketchUp.
      We have the following error message:
      Message de la page Web
      ERROR: Callback function error: L’objet ne gère pas la propriété ou la méthode « attachEvent » @ /dcbridge.js[601]
      OK
      To resolve the issue, you must update the Dynamic Component Extension HERE.
      Here is the method in image:
      http://i.imgur.com/npZnT6v.gif
      You can share this image with who you want and where you want. 😉
      Thank you
        Yes. This has been covered numerous times since the release of SketchUp 2017. The change to Chromium for handling web dialogs in SU2017 impacts earlier versions of SketchUp, too, so the SU extensions that depend on web dialogs need to be upgraded in the older version of SU. You should get an indication that there's a newer version of the SU extensions when you log into the Extension Warehouse.
        • TNTDAVIDT Offline
          TNTDAVID
          Hello Dave R
          The SketchUp 2017 installation should automatically update the "Dynamic Components" plugin,
          in all versions of Sketchup installed on the computer.
          This would avoid this kind of very unpleasant message.
          Here is the video solution with a little ambient music: 💚
