    Extension Signing
    30 Posts 5 Posters 4.1k Views 5 Watching
    • medeekM Offline
      medeek
      The plugin in question right now is my Medeek Truss Plugin. You can download it here:
      http://design.medeek.com/calculator/sketchup/medeek_truss_ext.rbz
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
        I heard from one of my coworkers that there appear to be an issue there the signing/uploading can fail at times when there are higher volume of traffic. I experienced this myself today when I tried to upload. At first I was getting just errors, but when I tried later with the same RBZ it worked fine.
        A fix is being worked on.
        • medeekM Offline
          medeek
          It took me about 15 tries before I got it to take the other night. Hopefully there is a resolution since this becomes annoying very quickly. It does not seem to be dependent on the encryption type selected.
          design.medeek.com
            We think we have the cause identified.
              Ugh... I'm suffering from this myself right now. 😞
                tomasz
                I have had this in beta and have reported it. My solution was to use a different browser then Firefox. Unfortunately even Edge was failing sometimes.
                It doesn't matter what is the content of rbz file. The signing fails even with the simplest rbz you can think of.
                Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                • medeekM Offline
                  medeek
                  I'm not glad it is failing but I am glad that others have identified the issue and it is just not me going crazy or trying to submit flawed .rbz files. Thank-you for looking into this and working on a resolution.
                  design.medeek.com
                    We rolled out a patch we think should fix this issue.
                      tomasz
                      Thanks. I confirm that the fix works for me. I can sign a plugin using Google account from Firefox without a problem.
                      • medeekM Offline
                        medeek
                        Its working great now, I'm using Chrome as my browser and zipping the files with Windows 7.
                        design.medeek.com
                        • 2 / 2
