    Extension Signing
    30 Posts 5 Posters 5.7k Views 5 Watching
    • medeekM
      medeek
      The signing process appears to be hashing my log files (.txt)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • Dan RathbunD
        Dan Rathbun
        Well, then do not put them into the package until after signing ?
        Or save your logs in a version independent folder like:
        "%APPDATA%/Medeek/SketchUp/TrussPlugin"
        I'm not here much anymore.
          The signing shouldn't be including your .txt files. Can you send me an example?
          In general I'd recommend you thread the Plugins folder like Windows' Program Files folder. If you have configuration files etc save them to the user's AppData. The extension update mechanism remove the old extension before copying over the new files. So that would also be an issue for you.
          • medeekM
            medeek
            The plugin in question right now is my Medeek Truss Plugin. You can download it here:
            404 - File or directory not found.
            (design.medeek.com)
            design.medeek.com
              I heard from one of my coworkers that there appear to be an issue there the signing/uploading can fail at times when there are higher volume of traffic. I experienced this myself today when I tried to upload. At first I was getting just errors, but when I tried later with the same RBZ it worked fine.
              A fix is being worked on.
              • medeekM
                medeek
                It took me about 15 tries before I got it to take the other night. Hopefully there is a resolution since this becomes annoying very quickly. It does not seem to be dependent on the encryption type selected.
                design.medeek.com
                  We think we have the cause identified.
                    Ugh... I'm suffering from this myself right now. 😞
                    • T
                      tomasz
                      I have had this in beta and have reported it. My solution was to use a different browser then Firefox. Unfortunately even Edge was failing sometimes.
                      It doesn't matter what is the content of rbz file. The signing fails even with the simplest rbz you can think of.
                      • medeekM
                        medeek
                        I'm not glad it is failing but I am glad that others have identified the issue and it is just not me going crazy or trying to submit flawed .rbz files. Thank-you for looking into this and working on a resolution.
                        design.medeek.com
                          We rolled out a patch we think should fix this issue.
                          • T
                            tomasz
                            Thanks. I confirm that the fix works for me. I can sign a plugin using Google account from Firefox without a problem.
                            • medeekM
                              medeek
                              Its working great now, I'm using Chrome as my browser and zipping the files with Windows 7.
                              design.medeek.com
                              • 2 / 2
