    Default tray in sketchup
    4 Posts 3 Posters 3.0k Views 3 Watching
    • xombie1912X
      xombie1912
      Hello everyone
      Asking if there is a plugin or some way to add plugins to the
      Default tray on sketchup
      example
      The default tray only works with this option
      Information of the entity
      materials
      components
      styles
      layers
      shades
      etc etc
      And if you want to create a new bar or a new section
      The only options you get are the same
      materials
      components
      styles
      layers
      shades
      etc etc
      There should be a way to customize this
      example
      Entity information
      materials
      (V-ray)
      round corner
      skater
      1001 bit tools
      etc etc
      And for what reason
      Constantly the community creates more plugins and that is very well
      But the more you have more saturates the screen leaving a minimum working space
      Please if someone sees this and can change something I would be very grateful
      regards
        Menu Display/ Tool Barr / New
        and you can put anything you want inside this new Tool Barr?
        • Bob JamesB
          Bob James
          How does this help him to find "a plugin or some way to add plugins to the Default tray on sketchup"
          • xombie1912X
            xombie1912
            Hi good day
            I tried that option as you mentioned it several times
            But this is very limited
            That's what i comment
            Has the same options and does not give you more
            Plugins can not be installed or moved to that tray
