Default tray in sketchup
Hello everyone
Asking if there is a plugin or some way to add plugins to the
Default tray on sketchup
example
The default tray only works with this option
Information of the entity
materials
components
styles
layers
shades
etc etc
And if you want to create a new bar or a new section
The only options you get are the same
materials
components
styles
layers
shades
etc etcThere should be a way to customize this
example
Entity information
materials
(V-ray)
round corner
skater
1001 bit tools
etc etcAnd for what reason
Constantly the community creates more plugins and that is very well
But the more you have more saturates the screen leaving a minimum working space
Please if someone sees this and can change something I would be very grateful
regards -
Menu Display/ Tool Barr / New
and you can put anything you want inside this new Tool Barr? -
and you can put anything you want inside this new Tool Barr?How does this help him to find "a plugin or some way to add plugins to the Default tray on sketchup"
and you can put anything you want inside this new Tool Barr?Hi good day
I tried that option as you mentioned it several times
But this is very limited
That's what i comment
Has the same options and does not give you more
Plugins can not be installed or moved to that tray
