    2017 is here
    82 Posts 31 Posters 9.3k Views 31 Watching
      @solo said:
      Not sure if you are asking me, if so then No, I do not have a plusspec license nor is it installed.
      Yeah, sorry I was asking you. I had that error on PlusSpec a versions back.
      • I Offline
        igacici
        I need to ask if someone might help me find what might be a problem... I tried several times to install new Sketchup 2017 on my notebook and it every time fails to install prerequisites with following error message
        "Component Universal CRT (Hotfix KB2999226) has failed to install with the following error message:
        "The installer for the Universal CRT (Hotfix KB2999265) timed out after 10 minutes. Please restart your computer and try the SketchUp installer again. If this does not fix the problem, use Windows Update to install the latest updates and try again. (Trimble Code 6)"
        The following components were not installed:
        • Microsoft .NET Framework 4.5.2 (x86 and x64)
        The following components failed to install:
        • Universal CRT (Hotfix KB2999226)
        See the setup log file located at 'C:\Users\muhammed\AppData\Local\Temp\VSDBA10.tmp\install.log' for more information."
        • 5 / 5
