    Standard views - How to change?
    6 Posts 4 Posters 718 Views 4 Watching
      atyp1
      Hi All.
      Can You advise me how to change the standard views (Top, bottom, front, back, left, right etc) in my model?
      I've tried to change the axes position and rotate them, but the views are still the same!
      I've tried also to use the "Solar-North" plugin to change the north direction angle , and this is also has no influence for standard views planes.
      So why the views are still the same? Why the program doesn't change them when You change the axes angle?
      I have also similar question . How to view the section cutting plan view in isometric mode, ("front view"), if the section plane is not parallel to the standard view orientation?
      Is there some method, which shows You front view of your section when it is not parallel to standard views directions???
      How to see that? How to do that?
      Thank You in advance for some advice.
      Adam
      • gillesG Offline
        gilles
        Right clic a face, choose Align the view in context menu, create a scene and name it front view ( for example).
        • JQLJ Offline
          JQL
          @gilles said:
          Right clic a face
          It must be a face, not a group/component.
          www.casca.pt
          Visit us on facebook!
            atyp1
            T h a n k Y o u !!!
              @atyp1 said:
              Hi All.
              You're thinking about it the wrong way.
              Axis orientation and north location just are not connected to nor do they control the standard views. By default the solid green axis is oriented to run away from the camera in the standard front view. You can change the axis orientation but not the direction the camera faces for each of the standard views.
              The ground plane is also fixed and by default, the red and green axes lie on the ground plane. The ground plane won't change location even if you move the axes.
              • gillesG Offline
                gilles
                Right clic a section , choose Align the view in context menu…
