    Sketchup V-Ray RT CUDA not working
    renderpluginsextensions
    6 Posts 5 Posters 4.9k Views 5 Watching
    • K Offline
      Kresudin
      i am using SKP 2016 pro + Vray v2.00.25, and have a GTX 1070 graphics card.
      When i select GPU CUDA in RT mode and start the RT render,
      i get only black screen and nothing happens..
      When i use Cuda rendering in Blender, everyting works fine..
      I uploaded image below so if anybody can help me i'd be very grateful!
      tnx
        Jahooby
        Did you find a solution for this? I am having the same problem...
          Macho3001
          Ditto here too !
          RT GPU not working.
          Anyone have any idea why?
          Macho3001
          3DADS
          'Leadership, by Design'
          3rd Dimension, Architecture Design Studio
            James Forest
            I've got the MSI Geforce GTX 1070 Armor 8G Oc graphics card and have the same issue.
            What i did was, start the render with rt cpu mode then switch to rt cuda mode and it started working. Not sure if it's a compatibility problem or not. Wish someone could explain in full detail the specifications of the vray rt render and these issues with graphics cards.I´ve read that it's still very grainy and a bit buggy in 2.0 version but saw a video of a russian guy making spotless renders. I really don't know how or why.
            Let me know if it solved the problem or if you managed to getting it to work from the start.
            • G Offline
              garibe
              I'm also having the same problem GTX1070 MSI X8.
              It is not possible that such a card does not work in RT mode
              • G Offline
                garibe
                If you start Render with OPENCL and then swap, it works. But in my gadgets the GTX 1070 appears with USED 0000MB. At least it worked. I thought my license was in trouble.
