    Huh? Cannot select visible object? Does not print.
    4 Posts 3 Posters 365 Views 3 Watching
      CalypsoArt
      I been working on a simple model that is a rework of an older simple model. When I printed one wall was missing. Exporting as an image gives the same result. Then I realized that I cannot select the problematic wall. It displays as it should on screen, but when I try to select it, the items behind it get selected. All layers are on. Is this some "D'oh" moment that I've never run into this before.
      • pbacotP Offline
        Graphics card issue? Try changing settings such as hardware acceleration.
          CalypsoArt
          Seems odd that it's one wall in one model and has never happened before with this machine and this graphics card. I saved the rest of the model as a component, opened it and built a new version of the troublesome wall. No problems so far.
            Charlie__V
            Was the wall you were attempting to select on the "cut" side if an inactive section cut?
            Did you close sketch up and re-start and try to select same?
            Charlie
