    Question about scenes
    6 Posts 2 Posters 537 Views 2 Watching
    • hellnbakH Offline
      hellnbak
      I don't use scenes very often, but in the model I'm working on now it would help to use a few scenes. But I'm having some problems.
      Here's what I would like to do - I would like to create scenes where all of the settings, including the North Angle and shadow settings, are maintained for each scene.
      That's all I ask, not too much, right?
      So if somebody could just tell me that it's not possible I'll go away and cry quietly.
        Jim
        The North Angle can be saved with the Scene iff you turn off Scene Transitions (in the View > Animation > Settings dialog.)
        But once you re-enable Scene Transition, your per-Scene North Angles are lost.
        • hellnbakH Offline
          hellnbak
          Hey, that seems to have done the trick, thanks!
            Jim
            I'm cleaning up an old "North Angle Animator" extension I've had around. Will post on Extension Store later today. It stores the North Angle per Scene and animates it between Scene changes.
            • hellnbakH Offline
              hellnbak
              Thanks Jim, but if that's the one I came across when I was researching this question, didn't it have a problem working on any version prior to 2016? Or maybe I'm thinking of something else.
                Jim
                I don't think so since I never released my extension. I just tried it and it works fine in SketchUp 2015.
