    Weird export animation behavior
    3 Posts 2 Posters 346 Views 2 Watching
    • Z Offline
      zibitguy
      I have a model in which any exported animation returns to the same scene at the end. I made sure the scene was not one of those included in the animation and all exported animations still returned to this scene at the end. Then I deleted the offending scene and that didn't solve the problem either. Then I deleted several scenes on either side of the sequence where the offending scene used to be and that didn't work either. It's not tragic, because I can fix it by going into Quicktime and deleting the end of the animation where it returns to that scene. But it's still annoying. Has anyone else seen this behavior?
      • pmolsonP Offline
        pmolson
        Under the animations options dialog box is there a little check box that says loop back to beginning or something like? that I seem to remember there is.
        • Z Offline
          zibitguy
          Yes, but that box is not checked and it doesn't loop to the beginning. It loops to a scene that is no longer there.
