    Using Sketchup for the whole process?
    4 Posts 4 Posters 466 Views 4 Watching
      Jorgensen
      Hi everyone πŸ˜„
      I normally sketch, create elevations, plans and sections in Revit.
      Then i link the revit file into 3ds max where i create illustrations.
      Sometimes when i need more control over textures and need to do fast adjustments to details, i export the drawing as dwg and then model and render in sketchup.
      I find sketchup very fast and intuitive, and have used it on / off for over ten years now.
      I wonder if i can create a complete project in sektchup? by this i mean
      • plans
      • sections
      • elevations
      • illustrations (i now i can)
      and set them up on A3 paper.
      I have tried some years ago, i think it was when paper layout was introduced. But i found it very troublesome and hard to get the needed drawings, especially nice plans, as sketchup is using faces, and not solids - so i needed to use some plugins to add faces to section cuts - what a hassle it was.
      I wonder if things have chanced since? what are your experiences?
      Jorgensen
      sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
        You should look at the work of architect Nick Sonder.
        • brettsichellodesignB Offline
          brettsichellodesign
            sonder
            Thanks folks!.
            Yes you can. I've been doing it for years and it works exceptionally well. Matt Donley and I co-authored a book on my process. You can see it here http://www.sketchupbook.com
