Help Quadface Tools
Hello everyone, I am currently working with the Quadface tools. I have a problem with the Lifemesh analyzes. That is, the quads, n-gons, and tris are displayed in color to detect errors. That works synonymous well, but how do I get the color away again? So the object becomes monochrome again. (Undo the function). Maybe someone knows what, thank you in advance ....
Just apply the default SketchUp material on the faces should do the trick.
Thanks, I thought there is maybe a short key or something, very thanks
I have an issue logged for being able to easily clean up: https://bitbucket.org/thomthom/quadface-tools/issues/100/remove-analysis-material-after-toggling-it
Very Thanks
Register LoginAdvertisement
