    [Q] Making realistic roof tiles
    18 Posts 6 Posters 2.6k Views 6 Watching
    • Bob JamesB Offline
      Bob James
      I have a need to create a randomly textured/colored set of paving stones composed of two shapes (square and rectangular) set in a quasi-repeatable pattern and four textures/colors. The random texturing is what will create the overall net random appearance.
      A few months ago I read a post in which someone wanted to create a set of roof tiles with a random texturing of the tiles. The tiles were created and placed on a roof. Then 3 or 4 variations of the texture were created. Then (and this is the part that I have searched the forum for for several hours) a random subset of the tiles applied to the roof were selected and one of the textures applied to them. Then, of the rest of the as yet untextured tiles, a random subset of those were selected and a second texture applied to them. Then, of the rest of the as yet untextured tiles, a random subset of those were selected and a third texture applied to them. Finally, the 4th texture was applied to the remaining untextured tiles.
      The result was a fairly realistic randomly textured roof.
      Can anyone remember that post?
      Attached is a picture of two sets of the real pavers.
      • PixeroP Offline
        Pixero
        SD Mitch recently created a Random painter script for me that would be perfect for this.
          charevir56
          Maybe this is what you looking for
          • PixeroP Offline
            Pixero
            Bob, see P.M.
              Bob James
              charevir56
              That's it!! Fantastic that you were able to find it.
              Thank you **very **much.
                Bob James
                Pixero
                Thank you very much: I'll give it a try tomorrow
                • HieruH Offline
                  Hieru
                  Another option would be to use Skatter and a selection of components with different textures. That's my preferred approach.
                  You can use FloorGenerator with random textures also, but this creates a lot of unique groups/components.
                  www.davidhier.co.uk
                  • JQLJ Offline
                    JQL
                    It's also a good idea as Skattering at render time should result in a lightweight sketchup file where you can use a simple texture on the roof faces that you use as skatter group.
                    www.casca.pt
                    Visit us on facebook!
                      Bob James
                      Since the pattern has four long pavers and four square pavers with each set sharing one square paver with each of the adjoining sets, I don't see how Skatter could be used.
                      • HieruH Offline
                        Hieru
                        If you model the entire section pictured, then create duplicates with varying textures, you can use Skatter with those.
                        I'm away from my computer right now, but I'll work up an example when I get back in the office.
                        www.davidhier.co.uk
                        • JQLJ Offline
                          JQL
                          This is your grid:
                          www.casca.pt
                          • HieruH Offline
                            Hieru
                            Unless I'm missing something using that grid means slicing through tiles, which isn't ideal for randomising.
                            www.davidhier.co.uk
                            • HieruH Offline
                              Hieru
                              So, because you can't get a perfect square or rectangle from this pattern I had to admit defeat using Skatter.
                              In the end I used a more manual workflow (helped with a few plugins):
                              1. Create 3 component versions of the tile pattern. Use one of them to create a large area of tiles.
                              2. Use Random Select at 30% and then use Component Replacer to replace the selection with one of the 3 components you started with. Repeat this several times using different components.
                              3. Create a plane for the finished tile area and use Zorro to slice up the components to create a straight edge.
                              4. Delete the unwanted geometry within the edge components. You can fix the holes in the geometry by selecting the edge components and using Fixit 101.
                              It sounds like a lot of work, but it should only take 20-30 minutes.
                              www.davidhier.co.uk
                                Bob James
                                Hieru
                                Nice workflow! Thank you for spending so much time on it.
                                Since there are many more than three initial color combinations it should turn out an interesting result.
                                I'd never have thought of using Zorro πŸ˜„
                                • HieruH Offline
                                  Hieru
                                  Glad you found it useful.
                                  I'm still wracking my brain for a faster way of doing it, but an easy solution is evading me at this point.
                                  www.davidhier.co.uk
                                    You can also use the very cool Random Component replacement by Sdmitch! 😎
                                    In my point of the view the more easy! πŸ˜„ (only one plugin to use except Zorro for trim the surface wanted)
                                    As your gride used is fixed you will obtain a more random result without effort!
                                    You have just to make 2 differents famillies of tiles Components Square & Rectangle!
                                    All the rest will be automatic! πŸ€“
                                    • Make the gride of component = 1 minute
                                    • Make individual textured tile component = 1 minute by familly (if you have yet each texture : can be infinite number of colors but also infinite clicks : so 12-20 textures colors will be more reasonable πŸ˜„
                                    • Running plugin : depending of surface but it's very speedy!
                                    If you want specific % of certain textures colors just multiply a component Source!
                                    If you want some rotations just create different rotation Source components!
                                    You can use individual Source Component or multiple module of components (pattern)!
                                    (with also different colors if needing)
                                      Example πŸ˜„
                                      All is separate 3D components!
                                      The only difficulty (if it's one) is separate Square / Rectangle families on the Target Model!
                                      (maybe you can put them on different layers! Plugin runs on all layers visible or not! πŸ€“
                                      For select all "Square Cubes" goto Components Windows Components
                                      Select Squares "Target" : Model Info / Name them "Target"
                                      Select Squares "Source" : Model Info / Name them "Source"
                                      Run the plugin
                                      Take a different name like Source1 / Target1 if you don't want clear the names "Target" & "Source" of the first replacement!
                                      Select Rectangles "Target" : Modele Info / Name them "Target" (or any name you want)
                                      Select Rectangles "Source" / Name them "Source" (or any name you want)
                                      Run the plugin
                                      Running the plugin is instantaneous!
                                      That's all! πŸ˜„
                                      You can make the same with complet patterns if you want! πŸ€“
                                      All that is games' boy and very very speedy! πŸ˜‰
                                        Of course components can be anything! πŸ˜‰
                                        With the famous Exploded View by CPlassais and... me! πŸ˜‰
