    Benches on The Hudson
    9 Posts 5 Posters 1.8k Views 5 Watching
    • G
      garystan
      Hi everybody :
                    This is a early evening scene.
                                              garystan
      • N
        nlipovac
        I think that shadows should be more elongated, if they are coming from Sun.
        • G
          garystan
          nlipovac :
                          Thanks for your comment.  Unfortunately, with the software, I couldn't extend the shadows any further.
        garystan
            Are you using a hdri background? If you do the sun should be turned off and the hdri should give you better shadows for the scene.
            • G
              garystan
              Mike Amos :
                        I'm using a .jpeg as the background.  It's just a software limitation on the angle of shadows.    Thanks for the advice.
        garystan
              • Bryan KB
                Looking good! That's just a jpeg background? Impressive!
                Honestly, you are steadily improving and this is quite good!
                • tuna1957T
                  tuna1957
                  garystan, Really like the tone of your render. I do agree that the shadows seem a little off for a sunset/dusk scene. I don't understand your comment about shadows limited by the software? You can get very raking shadows by adjusting the time and month settings in the SU shadow window. I've attached a quickie render as an example. The time is 6:30 pm, the day is August 26th. Both set in the SU shadow window. It got me the very long raking shadows you'd see late in the day.
                  • G
                    garystan
                    Bryan K :
                            Thanks for your comment......even though I  "hit a pot hole" now and then. And....even though I know there's more for me to learn.
        garystan
                    • G
                      garystan
                      tuna1957 :
                      Now THAT'S a shadow. Do you set the GeoLocation ? The reason I ask, is that (if I'm correct) by using GeoLocation, you set the Longitudes and Latitudes for the sun. Thanks.....................garystan
