    Need help in Vray Rendering
    renderpluginsextensions
    2 Posts 2 Posters 455 Views 2 Watching
      mil309
      hi, I need some help regarding my Vray Rendering. I'm still practicing though. so uhmm. can anyone help me troubleshoot this problem?
      I tried everything from adjusting the shadows, lighting, and even the Direct transformation, yet everytime I render it the problem is still the same. I truly appreciate your help. thank you πŸ˜„
      the upper part is so bright
        rspierenburg
        Are you lighting this with an HDRI Sky? If so then your HDRI is probably higher than your model, so either drop the HDRI or raise your model.
