    How detect that a file is locked by another app?
    13 Posts 5 Posters 1.6k Views 5 Watching
    • IltisI Offline
      Iltis
      Hello,
      After more than one hour of research, I already don't know how to catch the error when I export a file already opened by another application. 😡
      out_name = UI.savepanel('Location', '' , "#{File.basename(model.path).split(".")[0]}.txt")
      if out_name
         if File.extname(out_name).downcase != ".txt"	 # if the user erase the extension, rewrite it!
            out_name += ".txt"
         file = File.new(out_name , 'w')
         file.puts(%Q["blabla"])
         file.close()
      Error: #<Errno::EACCES: Permission denied - C:\test\test3.txt>
      Could you help me? I wanted to send a message to the user (and maybe to propose to increase an index at the end of the file's name).
      Best regards,
      Renaud.
        driven
        This works on my mac,
        out_name = UI.savepanel('Location', '' , "#{File.basename(Sketchup.active_model.path).sub('.skp','.txt')}")
        if out_name
              out_name += ".txt"
           File.open(out_name , 'w') { |file|
        in my Add_Note extension, I use this...
        module JcB
          module Add_Note
            def self.note2self
              mod = Sketchup.active_model
              mod_path = mod.path
              if mod_path.empty?
                Sketchup.send_action('saveDocument;' )
                UI.messagebox("Save with name and Try Again")
              else
                time = Time.now
                txt_path = mod_path.sub('.skp', '.txt')
                File.open(txt_path, "a+") { |file| file.puts("\n" + time.ctime) }
                UI.openURL('file;///' + txt_path)
                return 'note2self done'
              end #  mod_path.empty?
            end #  note2self
          end # Add_Note
        end # JcB
        JcB;;Add_Note.note2self
        john
        • IltisI Offline
          Iltis
          Hello driven,
          Thank you for your answer, but I think it's not what I need.
          In my case, in the real code (not my example here), the export is in a .dxf file. To test the quality/errors of the export, the .dxf file is open in a CAD software. Then, if I try in SU to overwrite the file with my plugin (after some modification in the SU model for example), and if the file is already opened in the CAD software, the file is locked by the CAD software. If I make this with a .txt file opened in Notepad++, there is no problem, because Notepad is not locking the file (and will detect the change!).
          I want to track the error and say to the user to close the file in the CAD software or to rename the file.
          (I'm french, sorry for my writting mistakes.)
          Renaud.
            out_name = UI.savepanel('Location', '' , "#{File.basename(model.path, ".*")}.txt")
            begin
              if out_name && ! out_name.empty?
                  ### if the user erase the extension, we readd it!
                  out_name += ".txt"
                file = File.new(out_name, 'w')
                file.close()
              else
                puts "Canceled"
            rescue Exception => error
              puts error
              ### or do something else like
              UI.messagebox("#{error}\nFailed to export file #{file}")
            • IltisI Offline
              Iltis
              OK, will try it. Thank you!
                Just noticed a typo!
                I corrected the earlier code snippet...
                if out_name &**&** ! out_name.empty?
                One other thing to note is that some types of file are locked by the app that opens them - like a dxf.
                But a txt file is opened by Notepad++.exe it is not locked, so its contents can be overwritten, you will then be asked when bringing that txt file's window foremost in Notepad++ if you want to reload it...
                So try using the dxf file...
                Or for a simple test write a .CSV file [remembering to force it to .csv, rather than .txt] AND have it already opened in Excel - which will lock it...
                  Jim
                  Did you try something like File.writable?("file")?
                  Class: File (Ruby 2.0.0)
                  Class : File - Ruby 2.0.0
                  (ruby-doc.org)
                  • IltisI Offline
                    Iltis
                    TIG, your solution is working fine. Thank you very much. 👍
                    Yes Jim, not working. 😞
                    BR,
                    Renaud.
                      Jim
                      In that case I would write it like this. You might rescue StandardError also, but rescuing Exception is too broad. You generally want to rescue exceptions starting with the most-specific and work up to the least-specific.
                      [1] https://www.google.com/search?q=ruby+rescue+exception%26amp;ie=utf-8%26amp;oe=utf-8
                      def locked?(filename)
                         locked = false
                         begin
                            file = File.open(filename, "w")
                         rescue Errno;;EACCES => error
                            locked = true
                         ensure
                            file.close if file
                         return locked
                      if $0 == __FILE__
                         p locked?("test.txt")
                        +1
                          Also, prefer opening files using block syntax so it always closes - saves you explicit rescue to close.
                            Jim
                            ...which actually simplifies everything.
                            def write_to_file(filename)
                               File.open(filename, "a") { |file|
                                  file.puts("Hello #{Time.now}")
                               puts "Could not write to file."
                            • IltisI Offline
                              Iltis
                              Thank you very much for these complementary solutions.
                              Renaud.
